First post, by prompt
the patch can be downloaded from sourceforge:
http://sourceforge.net/tracker/index.php?func … 551&atid=467234
In a different thread priestlyboy wrote:
I looked into that ISO + Wav/MP3/AFF Cue Sheet Thing by Martin Bättig and I can patch DOSBox with this but it won't compile for Windows because it uses librarys from Linux. The one i run into when compiling is LibGen and I am not a really good programmer and mostly work off of other peoples stuff to figure things out. But I know nothing about linux and its libraries so I can't do this or look into how to make it work with Windows.
I removed the dependency on libgen.h for windows systems (see new patch on sf.net). It is used to allow relative paths instead of absolute paths in a cue sheet. If anyone finds a gpl windows version of the dirname function, I will include it.
Note that the library SDL_sound from http://icculus.org/SDL_sound is required it you want to use any sound format other than raw audio files.
