Mobo type?
First post, by 8086-ProGamer
Hi Guys,
Can yhou tell me which type mobo this is? The only thing i know, it's a Soyo With an Intel Pentium 233MMX
Reply 1 of 11, by candle_86
Baby AT
Reply 4 of 11, by 8086-ProGamer
Jup, thx found it!
This is the Pentium 233MMX, am I correct?
Maybe i have to check the ram modules, or cache module. The PC is not starting at this moment, the screen is black 🙁
Should this CPU work with this mobo? It was installed on this mobo when I got it
The CPU does not start up at this moment. Maybe I should check the jumper settings
Reply 5 of 11, by meljor
Yes it is the 233mhz mmx. It is not for that board. The soyo is for the older pentiums without mmx (and other cpu's) that need a voltage of 3,4v according to the manual.
The mmx is a 2.8v cpu. It can work but only with a really good cooler. It is saver to use it on a newer socket7 board.
If the board doesn't start, try it without that coast module and expansion card. Use only 2 ram sticks and try a normal pci vga card. It could also be that the 233mmx is fried and you simply need another processor.
If the combination does work and you do want to keep the mmx in there, set it at 1.5x multi as the mmx sees that as 3.5x and that will give you 233mhz. And cool it.
Reply 6 of 11, by Markk
As far as I remember testing on several Soyo boards that do not support mmx cpus, if you tried using one it would run at 166MHz. No matter if it's a 166,200 or 233MHz model.
Reply 7 of 11, by 8086-ProGamer
Ok Thanks guys. Then I try to find a good CPU first for this mobo, and a good mobo for this CPU.
I dont want to burn it, or run it at lower speeds then possible
Reply 8 of 11, by wbc
Apparently this mobo does support MMX procesors, since it has a linear regulator on massive heatsink. Just get the right manual that mentions Pentium MMX and set jumpers according to it.
--wbcbz7
Reply 9 of 11, by 8086-ProGamer
Problem solved. 😊
The problem was, both FP and EDO RAM modules were installed. 🤣 The 233MMX is detected on this Mobo as 233MHz correctly
Next problem --> BIOS battery dead 😵
Reply 10 of 11, by ODwilly
8086-ProGamer wrote:
Problem solved. 😊
Good to see that you fixed your problem! There are lots of guides on here and around the internet to modify the RTC module (that big black ODIN rectangle)
Reply 11 of 11, by 8086-ProGamer
Lucky me 😊 !
Itś mounted on a Dip24 socket, now find a new ODIN RTC on ebay 😎
