First post, by Willie
If you've ever experienced the "Warning: file creation failed" error on a Windows machine, here is a tiny, incomplete explanation of why it happens and how you can fix it.
DOSBox complains with this warning when the file is marked as Hidden in "real-life"
DOSBox can see the file just fine and allows access to it, but when "creating"/modifying this Hidden file, it fails and returns a warning.
So, how to fix it? Simply hop out to Windows and edit the attributes of the file (either right click -> Properties) or use ATTRIB -h in a command window.
Unhide the file and you should be set.
As the subject implies, this is what I did to get Supaplex to save my levels/player list. (PLAYER.LST and HALLFAME.LST)
Hope this helps someone. This problem probably doesn't happen with Linux since the attribute of a "hidden" file is to simply start with a period if I'm not mistaken. I imagine that DOSBox would have no troubles with this.
Thanks and good luck everyone!
Reply 2 of 2, by MiniMax
Rank Moderator
Moderator
Added: FAQ
Thanks!
_________________
