AWE32 Issues
First post, by ab0tj
I recently acquired a CT3780 AWE32 card. It seems that the digital sound works fine, but all I get is noise when trying to play FM or AWE music. I have uploaded a video here so you can see what I mean: https://youtu.be/IfaJZiUTKnI
Any ideas on what is wrong with it?
Reply 1 of 10, by brostenen
Are all solder-points good on the card?
Reply 2 of 10, by bjt
I had a similar problem on an AWE32 I had once. On these cards both FM and AWE are routed from the EMU8000 chip to a DAC and on to the amplifiers. One of the tracks between the EMU8000 and the DAC was broken.
More info Crusty Desktop AT Pentium
Reply 3 of 10, by ab0tj
Thanks for the info. I will check when I get home from work tonight.
Reply 4 of 10, by ab0tj
There were a few scratches on the back of the card. None look deep enough to have cut any traces though. I'll try it in a different machine next.
Reply 5 of 10, by ab0tj
I just tried the card in another machine (Pentium 3) - The card behaves exactly the same in this machine. Not sure what to try next.
Reply 6 of 10, by bjt
Get a multimeter on the ends of the traces that have been scratched to check for continuity.
Reply 7 of 10, by ab0tj
Actually, I did just that last night. No open traces, no shorts between traces. Maybe it's time to just chuck it in the trash.
Reply 9 of 10, by Great Hierophant
Kamerat wrote:
You can always try to use an external DAC from the SPDIF header, but be aware that not all equipment likes the signalling levels (I think it's 5V).
The voltage can be used to drive an optical output header.
Reply 10 of 10, by ab0tj
Thanks guys. I think I will try using coax and a voltage divider to see if I get any different output from spdif.
I'm thinking this card may just end up in the trash and I'll use a combination of two of the cards I already have - AWE64, YMF719, CT2770 (SB16), CT1922 (Goldfinch). Any suggestions on which two? Looks like I have to choose between real OPL, 16-bit, no hanging notes, or resource juggling.
