Star trek Elite Force
First post, by Davros
Basically had to format c: drive and re install windows lost all the registry settings
So if you have it installed could you post your registry entries (obviously XXX out you cd key if its stored there)
thanks...
Reply 1 of 10, by leileilol
Elite Force does not depend on registry keys. All it ever asks for is your CD in the drive. Its CD key is stored in baseef/ and will still be there.
Reply 2 of 10, by Davros
The problem i have is I select new game and it just jumps back to the main menu (even if i type map borg1 in the console)
the game used to work fine
Reply 3 of 10, by leileilol
What does the console say?
sounds like the 1.0 engine headbanging into a 1.2 game dll.
Reply 4 of 10, by Davros
Sorry for the delay
Reply 5 of 10, by mirh
Setting file is in program files folder
You should try to run the game as administrator if possible
pcgamingwiki.com
Reply 6 of 10, by leileilol
It's pretty clear you're using a v1.2 client with the v1.1 game module (which should read April 10 2001 under the gamename: baseEF part). Patch up to 1.2 to fix this version conflict.
Reply 7 of 10, by Davros
There is a patch 1.2 readme in the game folder which makes me think I have patched it
cant reinstall the patch it thinks the game isnt installed
also the readme says
"Please note that that after applying 1.2 patch, it will update the HoloMatch code to 1.2, while Single Player will be upgraded to 1.1. If you had previously applied the 1.1 patch before installing the 1.2 patch, you will still see the Single Player version reporting as 1.1. This is completely normal."
Reply 8 of 10, by Davros
Tried a 1.1 (german) nocd and now its working
Reply 9 of 10, by leileilol
what it should've been
Reply 10 of 10, by Davros
I dont have an optical drive in this pc so I cant re install
could I have your reg entries so i can install the patch
