First post, by corpsicle
F1rst post for me on Vogons so i hope im in the right section and so on.
I recently got a Pentium 60 (with FDIV bug yay!) and its working great.
I installed Win95 OSR2.5 and its also working great.
Then i tried to install SubCulture from my original CD. It failed miserably.
I get the files listed but when doubleclicking on one it tells me it cant find it, or some file it depends on (its different depending on which file i click).
I can read the readme file on the CD.
So i put in my Win95 CD again and doubleclicked the installer, works fine.
I found a SubCulture iso somewhere, burned that to a CDR (file contents look identical to my original CD) and i get the exact same issues.
Could it be a Win95 driver issue or something?
I do get a yellow triangle on the harddrive controller in device manager. However the harddrive works just fine (as does the CDROM with any other CD).
Ive tried to copy the files from the SubCulture CD to harddrive, in windows and in dos, but it fails either on the first file or after copying two files.
