First post, by brostenen
So... I got this today, not tested out yet.
Before I test it. I have a question about a connector in the back of the card.
What is it for? (the neon-yellow'is thing)
I have searched the net for "GF4 ti4200 power connector" and it turned up nothing like this.
I don't recall GF4's having any power connectors.
So..
No manual is out there for this medion card, and no quick installation guide can be found.
I am actually lost here a bit. Is it a power connector? or a kind of Video/Audio something connector?
It looks like one of those Audio connectors, that are found on a soundcard. Just a different color.
If it is a power connector. What ratings or what cable to use?
Reply 1 of 11, by HighTreason
My two thoughts are that it is either an OEM card and that would be for RCA and S-Video on the front panel of the case, or else the Ti 4200 has capture capabilities and the connector allows audio to pass through to the sound card. I am more inclined to think the former is likely (front panel connector).
I am only guessing however. Chances are you can ignore the connector and use the card without it, as for testing out its function... No idea.
Edit: FrontX used to have an S-Video option which looked like that;
Packard Bell brought video to the front panel through the same connector;
Though the one on the other end seems to differ. It does certainly make that look like the most likely solution (S-Video/Composite In or Out).
Reply 2 of 11, by brostenen
Thanks.
Yeah. Most likely a tv/video/grabber something connector. I came across the mention of such technology, in the search of a GF4 card
with a power connector on it.
No mention of any such card that requires power and only mentioning of a MX card wich "comes without powerconnector", someone wrote.
So I guess that this is by no chance a power connector at all? 😀
Regarding that encoding stuff and video-in-framegrabbing-stuff. This is just something I probably will not use at all.
Perhaps I will. If I desire to do it. I just don't see any need for such technology at the moment.
Reply 3 of 11, by HighTreason
There is no chance it is power whatsoever. Even the Ti 4800 did not need a power connector, so the smaller Ti 4200 certainly will not need one. So yes, if you do not intend to use those features, ignore the connector entirely because you won't need it, the card should run as intended otherwise.
Reply 4 of 11, by brostenen
True that. 😀
I allmost knew the answer in advance. Yet I had to check, in order not to do something completely stupid.
And make an arse out of me self.
Reply 5 of 11, by Jorpho
Does the card have DVI-out? I vaguely understand that in some cases audio can be carried along with the video data.
Reply 6 of 11, by brostenen
There are two vga headers on the card, a s-vhs and a composit. No DVI-Out.
Reply 7 of 11, by shamino
It looks like an audio input, but that only makes sense if there's somewhere for the audio to go out the back.
At first I thought the connector at top was audio, but you've said it's a composite video. Is that certain, or could it be an audio jack?
Is that Mini-DIN connector only 4 pins, or does it have more? If it has more pins, it's possible some of them are audio.
Reply 8 of 11, by tayyare
Some laptops in the past has sound line out embedded into their VGA out connector, and came with some special VGA to RCA (Audio + Video) breakout cables. If this card has the same feature, this might be the sound input (looks like the proper connector for this).
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 10 of 11, by oerk
Nahkri wrote:
My medion geforce 3 ti 200 also has the same connector,it's some kind of video connector,connects to a box in front of the medion case.
http://www.2dehands.be/computer-game-consoles … -217140681.html
https://www.google.ro/search?q=medion+compute … vQ__PRB89nOM%3A
Almost certainly the case here. Just ignore it, or try to get the original media bay (might be easier and cheaper to get a complete system though...).
It's definitely NOT a power connector.
Reply 11 of 11, by brostenen
Thanks all.
Yeah. I remember those blue medion cases.
Allways wondered how they made that video-in without a tv-card.
