First post, by `Moe`
Hi!
This problem is a little off-topic, but I hope someone has seen this before and can give me a hint.
On my VIA EPIA board (VIA C3-2 1GHz, onboard audio), dosbox has horrible sound problems. Sound stutters massively, regardless of settings.
I am using Linux with ALSA, tried various dosbox versions. I believe it is _not_ dosbox's fault, as the exact same binary works fine on my 333MHz laptop. I've tried changing video/cpu settings in order to save CPU, but it doesn't change a bit. I've tried all sample rates from 8000-48000, and various buffer sizes.
One thing I observed is: Sound seems to play exactly at half speed. One buffer of audio is played, and then I get silence for the same amount of time, then again a bit of sound, silence again. This repeats continuously. I assume it's a single audio buffer being played, as I get longer sound-silence periods when increasing the buffer size or reducing the sample rate.
The funny thing is, the box is my TV (mythtv), it runs lots of (CPU/memory/disk-intensive) stuff just fine, no problems anywhere. So I'm completely lost why dosbox is the only program not working as expected.
Any ideas?
Reply 1 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
do you have something like kfreqd running ?
dosbox likes being run at good/constant speed.
I presume you don't run 24 bits display depth
did you try the latest cvs ? as it has some changes in the priority code for linux (run dosbox as root for best effect (those changes that is))
see if that helps.
Water flows down the stream
Reply 2 of 11, by `Moe`
No, the box is running without any power/frequency management. I tried CVS as of today as well as several older versions that happened to sit on my harddisk. One of them was the binary I am (happily) using on my laptop.
I've also tried various priority settings in 0.62, didn't make a difference.
Reply 3 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
tried those sdl defines ? like for dma and things like that ?
Reply 4 of 11, by `Moe`
yeah, even patched the SDL alsa driver to actually use DMA. Also enabled the via-sound kernel driver to support more than just 48kHz. Well, I think I'll go and look if there are more envvars for SDL. At the moment there is also some SDL-software compiling to check if it could be SDL's fault.
Reply 5 of 11, by `Moe`
Well, back I am. It seems like I already tried all existing SDL envvars, and a couple of SDL games all had the same behaviour: They worked flawlessly. Sigh. I feel an urge to scream.
Reply 6 of 11, by `Moe`
FYI: found the problem.
It is (more or less) an SDL bug. When using ALSA as sound driver, it allocates only 2 periods (a.k.a. fragments), which seems to be too little on some hardware. I don't know if it's the onboard sound (via chip, while the laptop uses yamaha) or the small CPU cache or whatever. After patching SDL to allocate 4 periods, dosbox runs like a charm, with the speed I'd expect from a 1GHz cpu, and everything.
I'll probably submit my changes to the SDL authors, so others are spared.
Reply 7 of 11, by Guest
I'm having the exact same problem(Soundblaster 5.1Live, AMD XP 1700+, 512Mb), and I'd like to know what this SDL is what you're talking about 😜
Reply 8 of 11, by Guest
Carrying on, I've now found out what SDL is (http://www.libsdl.org/index.php)... but how can I change SDL settings with DosBox? Must I download, fix and recompile by hand? 😜
Oh by the way, thanks for this great emulator ^^ I've been waiting for years to try some of those old CDs I have stored.
Reply 9 of 11, by Guest
Oh, one more interesting thing... when I capture audio with DosBox, the stuttering isn't there 😒 I have no idea what's going on.
Reply 11 of 11, by Guest
Okay, last post here... Would you mind sharing your patched version?
('guess I should've registered and edited all into one post, but still... 😜 )
