First post, by Guest
First of all... Hello to all people in the forums.
I have a problem with my mounted cd-drive. My mounting list is:
mount C G:\Emulatoren\PC\DOSBox\Games
mount D G:\Emulatoren\PC\DOSBox\Test
mount E H:\ -t cdrom -usecd 0 -ioctl
H: is my DVD-ROM. Dosbox shows, that "Drive E is mounted as CD-Rom", so everything should be okey. When I now type e: and try to list the contents of my inserted cd, by typing dir it does only show the following...
Directory of E:\
File *.* not found.
When I now type dir again, all the files are listed normal.
Tested this on different systems.
Hope I can help.
c ya
gdp2k
