First post, by JekhoOne
A Dos application for which i don't have the source, retrieves date and time info from Dos SO. Even if date/time format of Win7 where DosBox is running has following format :
dd/mm/yyyy ;
HH;MM:SS
the application retrieve a date/time as
mm/dd/yyyy ;
HH:MM pm/am.
How i can modify date/format provided to the application in DosBox 0.74 source code ?
Thanks in advance for your support.
J
Reply 1 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
If you're determined to tinker with the source then I suggest looking at the details of function 0x38 in dos.cpp and the associated country info table in dos_tables.cpp, but I think you will find it less trouble overall to boot real DOS and use its country system.
Reply 2 of 5, by JekhoOne
I would like to change the source. Booting real DOS will put in trouble the "operators" that will need to move application files from the image.
Looking to function highlighted by ripsaw8080 and related country info table, my only trouble is to know numerical value of specific fields in country info structure :
/* Date format */ 0x00, 0x00,
/* Currencystring */ 0x24, 0x00, 0x00, 0x00, 0x00,
/* Thousands sep */ 0x2c, 0x00,
/* Decimal sep */ 0x2e, 0x00,
/* Date sep */ 0x2d, 0x00,
/* time sep */ 0x3a, 0x00,
/* currency form */ 0x00,
/* digits after dec */ 0x02,
/* Time format */ 0x00,
/* Casemap */ 0x00, 0x00, 0x00, 0x00,
/* Data sep */ 0x2c, 0x00,
/* Reservered 5 */ 0x00, 0x00, 0x00, 0x00, 0x00,
Can someone help me ?
J
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
although if your applications reads the output from DIR you might need to change src/shell/shell_cmds.cpp
Water flows down the stream
Reply 5 of 5, by JekhoOne
Wonderful !!
Changing :
/* Date format */ 0x00, 0x00 -> /* Date format */ 0x01, 0x00, (European format)
and
/* Time format */ 0x00, -> /* Time format */ 0x01
all works well.
Thanks a lot. Now i am really so happy.
J
