First post, by brostenen
Have been looking at "adhesive glue" on Ebay. Most of what I find is just thermal grease and not glue.
Can anyone guide me to some of the real stuff, on ebay? Been looking for the cheapest avaliable.
Reply 1 of 17, by stuvize
You want something like "Arctic Alumina" never used myself but people say good things about it
Reply 2 of 17, by brostenen
A little over what I can find zallman glue for on the local shops.
Just thought that china would produce some more nasty stuff, that are extremely durable.
Reply 3 of 17, by firage
Well, there is, but who knows if it's any good. It's called "FD604" on eBay and elsewhere. I'd rather use a decent thermal paste and superglue.
My big-red-switch 486
Reply 4 of 17, by ODwilly
The Stars-922 thermal plaster works well, nasty stuff tho.
Reply 5 of 17, by brostenen
These looks like the same stuff, though I searched for both types...
http://www.ebay.com/itm/FD604-Heatsink-Therma … RIAAOxyaURThZk1
http://www.ebay.com/itm/1x-CPU-GPU-Thermal-Si … HEAAOSwk5FUweJ-
They are cheap... Just wonder if they are really nasty. Nasty as in "extreme binding and for love of all don't get on you'r hand's"
I want to use it for adding some chipset heatsinks (from dead mobo's) to some ram chips on various graphic cards and stuff like that.
Reply 6 of 17, by ODwilly
That is exactly what I used it for and it worked well, not as good as the more expensive stuff but better than I expected. It smells TERRIBLE. I think it takes awhile to cure so you have plenty of time to get it off your hands before it turns into a problem.
Reply 7 of 17, by brostenen
ODwilly wrote:
It smells TERRIBLE.
That's the stuff I wan't. Can't argue on the price eighter. And the plus-side, I get to "fuck" mother nature on that cheap shipping from China.
How much will my shipment pollute I just ask 🤣 🤣 🤣 If you need to do it, do it right.... 😉
Naaa... For real, how is this even possible to do? Manufacturing and shipping at these prices?
Reply 8 of 17, by brostenen
Bought this one:
http://www.ebay.com/itm/FD604-Heatsink-Therma … GIAAOSws65Tmbmd
And 20 small 8x8mm alu-heatsinks if I should run low on the Chipset heatsinks that I have gathered.
Reply 9 of 17, by joe6pack
FWIW, this is good stuff. I ordered some to stick a heatsink on the xbox 360 southbridge, and I've ended up using it for a ton of other stuff. Never knew I needed it until I got some 😀
Reply 10 of 17, by raymangold
Haha, before I opened this thread I was thinking of the "Stars" stuff. I bought some myself. Apparently it's not super super strong, so with a butter knife you can pop off anything attached with it.
Reply 11 of 17, by ODwilly
I love the Arctic stuff but hate the cost and semi-permanence. The trick with the Stars stuff is to do a thick glob instead of an even spread from what I understand, with a thin layer it lacks a good bond and falls off.
Reply 12 of 17, by TELVM
brostenen wrote:
... I want to use it for adding some chipset heatsinks (from dead mobo's) to some ram chips on various graphic cards and stuff like that.
I just super-glue that kind of smallish heatsink stuff.
Super-glue (0.11 W/mK) isn't as good a thermal conductor as true grease, but is an order of magnitude better than nothing (air = 0.030 W/mK), and in practice works fairly well.
Let the air flow!
Reply 13 of 17, by dr_st
I may have been out of the loop too long, but why would anyone want thermal glue as opposed to regular thermal grease?
Reply 14 of 17, by alexanrs
To attach heatsinks to GPUs/chipsets or anything that does not provide a way to attach one, like holes.
Reply 16 of 17, by candle_86
if all else fails just use large rupper bands around the item 🤣
Reply 17 of 17, by swaaye
There's another thread about this topic that's a day older so let's discuss it there. Thanks.
