First post, by Zira
under FreeBSD after install with prefix "/usr/local/dosbox i can't find file with configuration. Where I can get one?
I've create ~/.dosboxrc but what to write there i dont know %)
Reply 1 of 2, by Markus
You can't find it, because there is no dosbox.conf until you create one.
Create one with the default settings inside dosbox like this:
config -writeconf /path/to/dosbox.conf
To find out, waht to write/change there, read the accompanying readme-file and take a look at http://dosbox.sourceforge.net/wiki/index.php? … age=dosbox.conf
