Black screen on start
First post, by G-Three
DosBox 0.62 isn't displaying any output in the DosBox window when I fire it up. Oddly 0.61 runs well enough.
It just creates 2 windows: The console output and the black DB window with the usual title (DB 0.62, Cpu Cycles, etc..). This regardless of the .conf option fullscreen=true/false. I tried several of the output modes to no avail.
An interesting bit is that if I start it with fullscreen false, activate the DB window and press alt-enter (to FScreen it) it actually only captures the mouse cursor.
This on Windows 98SE.
Also, as a feature request: Keyb - command 😉
Reply 1 of 5, by Guest
I copied the SDL.dll file from the DB 0.61 and for some odd reason the DB 0.62 window seems to be working now. Haven't tested anything yet...
Reply 3 of 5, by Suns
Here i get a black window in various settings, in version 0.60 0.61 0.62 and 0.58...
I have my lastest video drivers, and every other things run nice.
i try to put my sdl.dll compiled from mingw, and same.
only opens sdl window change windown caption. i can use short keys, and everything, but not on the screen
win98 SE2
sis5597
64mb ram
Reply 4 of 5, by Suns
Well is a k6 mmx 300mhz too
when i hit CTRL + F1, i get output...
but i cant exit the view of keys...
neither exit dosemu
Reply 5 of 5, by robertmo
just a guess - plug more ram into your pc
