First post, by kanecvr
Hi guys. I aquired a Voodoo 4 4500 today and it's notched for both 1.5V and 3.3V AGP. Looking online I could not find clear info about this card, and I'd frankly love to run it on my 939 rig for some benchmarks - BUT - I'm afraid it might kill the card.
Do any of you know for sure if the card supports 1.5v AGP? Is there a way to get a manual for it?
So far I've tested the card on an Acorp 7KT266AL mainboard with universal AGP and it would not detect the video card until I plugged in a Matrox G450 and set AGP from Auto to 2x mode in BIOS. Now the card is running and I'm installing win98.
Here's a pic of the card:
Reply 1 of 28, by PhilsComputerLab
AFAIK the V4 4500 is an exception and works with both voltages. I'd be surprised if this one is different, but you never know.
YouTube, Facebook, Website
Reply 2 of 28, by kanecvr
The AGP slot notching would indicate that you are correct, but I really don't want to risk the card...
The MOSFET present on the board seems to only take 3.3V power: http://pdf1.alldatasheet.com/datasheet-pdf/vi … SEM/US1150.html and convert it to 2.7V.
I found this: http://hw-museum.cz/view-vga.php?vgaID=170 - spec table indicates it is an AGP 2x board, but it does not say if it will take 3.3 or 1.5v
UPDATE:
Ok so I figured it out with the help of Falconfly.de:
Only the retail 3dfx built Voodoo4 4500 AGP is 4xAGP 1.5V capable. The Powercolor Evilking Voodoo4 and the rare 3dfx Voodoo4 4500 "L" Shaped variants are confirmed to be 2xAGP 3.3V only
Conclusion: If you happen across a PowerColor or L shaped 3dfx Voodoo 4 cards, DO NOT plug them into a 1.5V AGP 4x/8x board.
My test rig hasn't finished installing win98 yet (had some trouble with the 80GB HDD) but I'll post some benchmarks when it's ready.
Reply 3 of 28, by PhilsComputerLab
Good to know!
Reply 4 of 28, by kanecvr
Fun little fact - while playing around with the drivers, I found "digital SLi" and "SLi Compatibility" under 3dfx advanced features tab. Makes me wonder if one could chain up two voodoo 4 4500 or voodoo 5 5500 PCI w/o a bridge for better performance...
Reply 5 of 28, by PhilsComputerLab
AFAIK the V5 used internal SLI for the two chips. Maybe it has to do with that?
Reply 6 of 28, by kanecvr
Benchies!!!
The test system is:
- 1100MHz AMD Duron
- Acorp 7KT266AL - VIA KT266
- PowerColor Evilking Voodoo 4 4500 AGP (32mb)
- 256MB DDR333 @ 266Mhz
- 80GB Maxtor DiamondMax20 (rebranded seagate?)
Results:
3DMark 99 @ default:
3DMark2001 @ 1024x768 - 16bit color
3DMark2001 @ 1024x768 - 32bit color
The card seems to score in 32 bit mode about as much as my Voodoo 3 3500TV on my XP 2400+ in 3Dmark 01 does in 16 bit mode, and about 300pts more then the aforementioned setup in 16 bit mode, witch makes sense since it has a bigger framebuffer.
Reply 7 of 28, by havli
Some people claim their PowerColor V4 is working in 1.5V AGP 4/8x MB. Maybe it depends on PCB revision, who knows.
Anyway the safe approach is to use only 3.3V capable motherboards with Evilking IV. It is rare piece of HW and it would be shame to kill it by using wrong MB.
btw - there are other videocards that have the AGP 4x notch but do not support 1.5V AGP.... like Rage Fury MAXX and some varints of Kyro 2.
Reply 8 of 28, by nforce4max
The powercolor version is 3.3v only but the reference version is 1.5v, there is a safe way to test but lost the link. You will need a few things but doesn't require a board.
Reply 9 of 28, by kanecvr
If there is a way to test I'd be happy to try (as long as it will not harm the board).
Frankly, I don't think it will - lower voltage should not harm the card - theoretically plugging an AGP 8X 1.5V card into a universal AGP slot previously setup for a 3.3V card should indeed do damage (and I've seen this happen). I don't see how supplying 1.5V to a card that requires 3.3V could harm the video card (but I'm sure someone can explain it to me).
Before putting the V4 in my test board, I had a Geforce 4 Ti 4200, so the Acorp was setup for AGP 4X. When I first plugged in the V4 the mainboard acted like it had no video card installed (1 long and 3 short beeps). Tried to power it on twice, re-seated the V4, tried to power on again - still video card error beeps - finally I plugged the GF4 Ti back in, went into BIOS, set AGP to 2x, set fast writes and burst write to Disabled, plugged in the V4 and it worked.
Reply 10 of 28, by alexanrs
kanecvr wrote:
A lower voltage on the signal lines should not harm the card... but the card using is 3,3V signals on a motherboard expecting 1.5V - the motherboard is the one in the line of fire here.
Reply 11 of 28, by mwdmeyer
If I remember correctly there is a mod to make the card work at 1.5volts.
I've never tried it myself. I have a few of these EvilKing cards.
Sorry I cannot find anymore info about the mod at the moment but I will keep looking.
Reply 12 of 28, by kanecvr
I bet it implies replacing the 3.3v regulator with a 1.5v regulator and switching around some resistors - but I'm not willing to try it on a Voodoo 4...
Reply 13 of 28, by anthony
Just solder 4.7k resistor to r97 and enjoy. This mod will add universal agp support
Reply 14 of 28, by PCBONEZ
Changing regulators will not help you. That usually has to do with power voltages. [Vcc.]
Then they talk about 3.3v vs 1.5v for AGP it's about the *SIGNALING* voltages, not the power voltage they run on.
Both the mobo and the card have to be capable of using the same signaling voltage or it won't work.
If the card has the key cut for 1.5v signaling then it most likely can use 1.5v signaling.
It was the later technology. Does not make sense they would cut that key slot if the card wasn't capable.
There is a great AGP reference here: http://pinouts.ru/Slots/agp_pinout.shtml
That one shows the pin assignment differences between the AGP types. Most don't.
[edit.]
Reply 15 of 28, by kanecvr
R97 is right above the AGP key right?
PCBONEZ wrote:
Changing regulators will not help you. That has to do with power voltages. Then they talk about 3.3v vs 1.5v for AGP it's about […]
Both the mobo and the card have to capable of using the same signaling voltage or it won't work.
I see - thanks for the explanation - now it makes sense.
Reply 16 of 28, by anthony
yes
Reply 17 of 28, by PCBONEZ
kanecvr wrote:
R97 is right above the AGP key right? […]
Oh no, I type so slow...
Reply 18 of 28, by Gamecollector
The easiest method to test - an Universal AGP MB. Asus CUSL2 or something similar...
These MBs work in both 3.3V and 1.5V modes so you can't fry anything.
Reply 19 of 28, by kanecvr
The board I'm using has universal AGP, and as far as I know, while supporting AGP 4x, the CUSL-2 only works with 3.3V cards (It will work with my AGP 4x A250LE but won't with my AGP 8x A280LE - 1 long 3 short beeps). Then again mine could just be weird.
Like I wrote above - when I plugged the video card in my test board for the first time, it was not being detected because the board previously used a 4x GF4 Ti. It only started working after I manually set AGP to 2x from BIOS.
