First post, by Un Information
Like instead of DOSBox itself doing it? I've tried to see if it could work, but all I get is a tiny screen surrounded by black.
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
i am not sure DOSBox itself is doing the scaling. DOSBox uses a graphics library called SDL (Simple DirectMedia Layer) which in turn utilizes OpenGL and DirectX. And hopefully OpenGL/DirectX is smart enough to pass the task of scaling directly to whatever driver you have for your graphics card.
My question is: Why do you want to let the monitor do the scaling?
_________________
Reply 2 of 5, by PhilsComputerLab
Just to clarify what you want. Do you "just" want the image to be full screen?
YouTube, Facebook, Website
Reply 3 of 5, by Un Information
Because with CRT monitors you get those "lines" and I appreciate that look.
Yeah, but not scaled by DOSBox.
Reply 4 of 5, by PhilsComputerLab
I remember an existing thread about this, might be worth looking at some of the older threads.
My personal take is, if you care that much about authenticity, use a real DOS machine 😀
Reply 5 of 5, by Malvineous
Have a read of the comments in dosbox.conf. It says you should use "fullresolution=original" if you want the monitor to do scaling, and if you get a small picture with black around it, to try a different output device as the one you are using does not support that resolution.
Using "fullresolution=original" will cause DOSBox to tell the output surface (e.g. OpenGL) to change resolution to whatever the game uses, like 320x200. It will only work if 1) the output method supports changing of the screen resolution ("output=surface" appears not to) and 2) your operating system, video card and drivers are capable of setting that resolution.
