OA3
Reply 20 of 28, by Tertz
leileilol wrote:
I'm getting better at making terrain
Every game should to have something special. Such thing in yours seems to be big tits!
If you'll make them animated, then there will be a noticable improvement above UT.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 21 of 28, by dr_st
Wouldn't it be a copyright infringement of Qbix's avatar?
Reply 22 of 28, by leileilol
new fire
I did a trick that gets extra frames from an 8 frame animmap, so this is more animated than the typical fire this replaces
    110.83 KiB
Reply 24 of 28, by leileilol
I wish I released it in 2010, but things are lonely and slow 🙁
though while it was slow it helped me take time to revise one character a bnuch to find an ideal art style working out for my abilities and targeted specs.
Reply 25 of 28, by subhuman@xgtx
A one person project is no easy thing you see, but better to know you were able to use that to your advantage. 😀
Is there anything I could for you? Fe. performance testing and bug reporting related? I have about 5/6 systems here ranging from MMXs with V1 4/6mb till a P3 1400 with V2 and M3D, so I'm happy to help if you desire. 😀
Reply 26 of 28, by leileilol
back to work. revised roguess with more better shape and geometry and more finished pants. initial rig without any weight polishings at the moment
Once in awhile I do fire this up in PCem to get an approximate P166+fastV1 system to 'profile' my assets to see how I could make them faster/better. It is my intent to be optimal and avoid the mistakes OA and even Q3 did with their materials
There definitely is a higher polygon count though and LODs on MDRs aren't implemented yet.
EDIT: and now succubus. probably a bit too endowed for someone here 😜
    59.98 KiB
    43.6 KiB
Reply 27 of 28, by leileilol
OK I'm bumping this because i've been trying to get this back to Windows 95 (no KernelEx and "service packs") and i'm feeling pretty warm right now with some mild success
Cji9WqPWYAE5lzq.jpg:large
I restored the console window, removed a PSAPI dependency (for ONE EnumProcesses function!) and slipped in a wspiapi.h (Winsock2 stuff)
wspiapi.h from reactos used.
(also i've implemented texture pages which helps optimize assets a bit better (and allows animation for alpha modulated stuff, so rage pros and s3 virges aren't left out 😀 ). definitely does bench a little faster in pcem's voodoo graphics emulation now at least)
Also here's an issue tracker.
Reply 28 of 28, by leileilol
This is an old thread I know, i'm still working on this behind the scenes.
What i'm going to focus heavily on now are items. I have benchmark results comparing item models' performances between games, the OA3 items set is largely incomplete at this point (missing models shows how high the performance could potentially be anyhow)
15.82 KiB
15.43 KiB
ARTIFICIAL
Q3's are slower on Pi due to texture usage, while OA's is slower on Voodoo2 due to polygon count (CPU bottleneck as well)
PCem's emulation of the V2 is fairly realistic performance-wise and can also emulate the same cache-thrashing of a real card, so it's a bit of a convenient to test with asset-making wise. I do have real hardware, i'm just lazy at this point
320x240 so the Pi's horrible GL driver doesn't bottleneck (a slow buffer grabbing is involved), and the V2 in the same res allows the same LOD range and such even if it's stuck in the corner.
DISCLAIMER: These charts are NOT "haha voodoo2 pwns the pi!!! 3dfx rulez!" charts and you are a fool if you imterpret them that way
