First post, by second guest
I don't rescue to mount c: because i don't know the name and the path of my directories: how does this work on mac osx? I tried like
mount c harddisc or mount c users\admin\desktop and so on but i think i'm failing because of my ignorance of the mac working system
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
try mount c /
or open an terminal (thing where you have to type commands)
go to you games directory
dosbox ./
or download radnor or petit dosbox (both avaible from the downloads page at http://dosbox.sf.net
Water flows down the stream
Reply 2 of 4, by Guest
I thank you but i either dont know how to open a terminal session or launch the programs you linked to me. Could you help me please?
again thanks for your time
Reply 3 of 4, by guilly18
At least regarding Petit dosbox, you do not run the front-end from a terminal session, just as you would with any other Mac OS X program.
From Petit dosbox make sure you specify both: the path where DosBox is stored and the path of the drive you want to mount. That, you can do by using the Browse/Set path buttons. Just navigate through your Macintosh file system as you would do with any other program to select the path!
Reply 4 of 4, by Guest
I finally tried the / and it effectively works better.
Thank you
