First post, by feipoa
Can someone tell me how to toggle the frame rate counter in the 1998 PC game Incoming? The following website says to hit F10, but it did not do anything. Reference, http://ca.ign.com/cheats/games/incoming-pc-2282
Reply 2 of 4, by feipoa
Thanks!
At the main menu, type NUMBERONEDACRESTREET
Then press F10 in game.
Reply 3 of 4, by feipoa
That did not work either. After some trial and error, I figured out that you need to hit the TAB key to bring up the fps display. Here's the order of things:
1. Load the game.
2. At the first menu you see, type NUMBERONEDACRESTREET
3. A new menu will now appear. Turn on the option to enable cheats.
4. Press ESC to leave this hidden menu.
5. Press the TAB key. A frame rate display will now appear.
Reply 4 of 4, by Davros
I dont know if i'm allowed to ask but
does anyone have a nocd ?
mods delete if not appropriate
