First post, by Proud_Persian
Ok sorry if this has been posted before... But i have been looking up and down on this site to find the answer, and it wasnt so clear.
I'm trying to run LSL7 on my mac, and someone suggested that i change the core of dosbox to dos32a, since i got the error message that had something to do with dos4gw! Ok i have downloaded Dos32a_720.zip and i dont know what else to do!
So my question is how do i change the core of DosBox from Dos4gw to Dos32a? If u could provide me with steps i would be forever thankful. Thnx in advance! 😉
Long Live Iran(Persia), Long Live Freedom!
Down with the Islamic Republic
Reply 2 of 10, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Once more (I already replied in your other thread and I remember somebody else telling it to you as well): READ THE FOLLOWING THREAD!!!
STTNG: A Final Unity Installation Guide for DosBox
Mirek
Reply 3 of 10, by Proud_Persian
Thnx for the links... but i had been to the first link and unfortunately it wasnt there dos4gw, so i couldnt do that, it was embedded!
Amazingly i had searched everywhere on the forum, and i had not come across the second link, so thanx alot of that!
But heres the thing, i put the SB.exe file into the directory and the i tried SB /R /BNsier.new sier.exe or even lsl7.bat
And it kept saying that i need to reinstall dos32a... any ideas?
And after that there was no new file, eg. sier.new for me to rename to exe... so whats going on?!?
Reply 4 of 10, by mirekluza
DOSBox Moderator
I think that this is because you did not set environment variable SET <i_do_remember_now_what> for DOS32A extender pointing to its installation directory. See the thread once more. 😀
Ok, I quote here myself:
1. Unpack DOS32A files into a directory on your disc
2. Set the evironment variable pointing to it, e.g. set DOS32A=c:\DOS32A
3. Now it should work.
Mirek
Reply 5 of 10, by Proud_Persian
Ok thnx for the help... i managed to change the core!
I had to copy the BINW folder into the game directory
and copy SB.exe into the game directory too. Then type
set dos32a=c:\
And then SB /R /BNsier.new sier.exe
finally backup the original sier.exe file and rename sier.new to sier.exe!
But now i face a new problem! 😉
"Can not find 999.pal resource.
If this is a CD-ROM game please make sure that a CD-ROM is loaded.
If you continue to experience this dialog make sure your CD-ROM drivers are loaded properly. DOS/32A warning (9003): real mode interrupt vector had been modified: INT 24h"
Ok u see when i loaded the game in Virtual PC under the emulation of Win98 it doesnt ask for the CD or give me an error. Or even when i load it from DOS. Now how can i fix this problem? I dont have the CD.
Reply 7 of 10, by Proud_Persian
I've played around the Resources.cfg file and up to now i wasnt successful. Any ideas?
Reply 8 of 10, by Alexsource
If the file IS in the directory/folder, then it means it's corrupted. Either way, you should get a replacement, i think....
Reply 9 of 10, by Markus
Are you sure with dos4gw?
I thought sierra used dos4g, which is a quite different extender and dos32a is not too compatible with it...
Btw: there's no need to replace the core with sb, you can always do:
dos32a.exe someprogram.exe
Reply 10 of 10, by Magamo
That resource not found error sounds suspiciously like the one encountered with Space Quest 6. I detailed a way to get around that issue in another thread for SQ6. Give it a whirl with LSL7.
