First post, by ExTneicsol
It is only me or when we use line in the card (ultrasound of course) close the line in ... but keep the cd in open? I've i setup that i use as much line in as i can but i just find out that. I've read somewhere that some game on the gus close the line in ... but could it be ultramid that does that?
Reply 1 of 4, by elianda
Ultramid can open Line-In using the '-l' parameter. You can also call ultramid -? to get help.
A regular GUS has no CD-In.
Usually a GUS with CD-In also has the ICS mixer chip, so try ultramix.exe.
Youtube Channel
Reply 2 of 4, by ExTneicsol
Oh, thanks for the tips! My Gus is a MAX. So i've use the cd in with a asus mp3 in (back panel with a 3.5mm jack to cd in) to add a line in. (see redneck mixer topic). i use the line in of the gus and the cd in for a mt-32 and a sc-33. I use the line out of the gus to the line of my awe32. 😀
Reply 3 of 4, by elianda
Well, might be an opportunity to think about getting an external mixer 😉
Youtube Channel
Reply 4 of 4, by ExTneicsol
Finding something that fit the setup is not easy 🤣 I'm a bit picky.
