First post, by Tom93
DOSBox has been working fine until I upgraded to Windows 10.
Now, when I activate the keyboard mapper with CTRL-F1, the screen comes up blank.
If I click around in the dark in the blank screen the contents eventually appear, but I have to click things several times to actually select them and do anything, and the screen doesn't update, but it does seem to work.
My game seems to still work fine 😀
Is anyone else having this issue ?
Does anyone have a fix ??
Reply 1 of 3, by Yesterplay80
Which version of DOSBox are you using? Have you tried a current SVN build?
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 2 of 3, by Tom93
I have version 0.74 of DOSBox. I intend to try the current SVN build if I can get it to build on Cygwin.
Reply 3 of 3, by bloodbat
Why Cygwin? It should build straight with Mingw or Visual C++
