First post, by sodaddict
Just so we're clear; i am a noob at DOS coding and what not.
I am trying to install 3DFX onto DOSBox so i can run GTA 1 in 3DFX mode, but i've tried every way possible and i always end up failing with the "unable to find DLL" error. No luck trying to find my problem or anything else on google.
I need help installing 3DFX onto DOS, in the most simple and easiest way possible.
Reply 1 of 17, by sodaddict
bump
Reply 2 of 17, by keenmaster486
Um, this is a DOSBox question and belongs in a different subforum. And you don't have to bump your thread after only five hours 😀
But sorry, I can't help you with your question except to say that real hardware would be better, which is not helpful at all 🤣
Although it would be much more helpful if you posted your system specs, what version of DOSBox you're using, the specific DLL error you're getting, etc. Vague questions like your OP don't attract much help.
World's foremost 486 enjoyer.
Reply 3 of 17, by Stiletto
Moved to DOSBox forum.
do the Fandango!" - Queen
Stiletto
Reply 4 of 17, by Arctic
Maybe it helps:
With a real Voodoo 1 you install the driver and then copy the Glide2x.ovl
from windows\system\ to the GTA directory 😀
Reply 5 of 17, by Sammy
You have to install a glide wrapper (nglide for example).
Remove all glide*.dll files from dosbox directory.
In dosbox there should be a glide2x.ovl und glide2x_emu.ovl
copy one of them to your game directory (depends of what you have set in dosbox.conf emu or not) and maybe rename it to glide2x.ovl.
Reply 6 of 17, by Jorpho
Except you also need a build of DOSBox with the Glide patch, and at this point we have no idea what Mr. Sodaddict is doing.
Reply 7 of 17, by Sammy
oh yes, i forget.. because i only use dosbox version with 3dfx patch.
i would try dosbox daum from 6 may 2013
Reply 8 of 17, by Jorpho
Where do you get old versions of DOSBox Daum, anyway? There seems to be general consensus that the latest builds are broken (though I'm not exactly clear how or why).
Reply 10 of 17, by Yesterplay80
Or you could download my 3Dfx build, it is built using kekkos 3Dfx patch and outputs the image with opengl and doesn't need a wrapper. The link is down in the signature.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 11 of 17, by Sammy
ahhh, great. Do you have to ne2000 patch build in too ? or plan to build it in?
Reply 12 of 17, by Da Easy Mitch
No and no. 😀 It's just plain vanilla and vanilla + 3Dfx.
Reply 13 of 17, by Sammy
to bad, i am still searching for an all in one dosbox:
- with 3dfx
- with network (for multiplayer games)
- and win9x should run stable (with network, sound and 3dfx)
Reply 15 of 17, by keenmaster486
Either we have forgotten about the OP, or he has forgotten about us 🤣
Reply 16 of 17, by Sammy
collector wrote:
Then you are best off looking at something else other than DOSBox.
Dosbox and pcem are the only Programms with 3dfx support.
PcEm is a lot slower than Dosbox.
So i hope for a Branch for win9x, 3dfx, and network.
Reply 17 of 17, by lightmaster
He only did try and he needed another thing. Enough said.
