First post, by Guest
It really pisses me off that i cant play any games except crappy Jazz Jackrabbit cos of this "illegal call 7" error! I am trying to get Duke Nukem 2 to work but it has that damn error! Somebody help!
You should read the POSTING GUIDELINES in the FAQ section of the forum, dude.
What version of DOSBox are you using? Which Operating System? Did you try replacing SDL.DLL with another version (maybe the one from DOSBox 0.61)?
Jazz Jackrabbit should works ok. I do not have Duke Nukem 2.
Next time post in proper forum (DOSBOX Games/Apps) with details (what you did) and with proper subject.
Mirek
duke nukem 2 doesn't work due to stupid programming
we made a fix for it search the forum
the next version of dosbox will have that fix included though.
we;ve become less strict.
Water flows down the stream
Both of those should run perfectly with VDMSound. Even on XP.
