Aces of the Deep
First post, by LobsterbakXXI
Ok I have the newest version of DosBox and the CD vs of AOtD...When I go to run the game it plays the intro movie - but then returns an error saying it can't find a resource.cfg - i looked in the games folder and theres one it there..
Is there a problem with the installer? 😕
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
1. How did you install it?
2. How are your mounting the drives in DOSBox?
3. What does that resource.cfg contain?
_________________
Reply 2 of 8, by LobsterbakXXI
i installed in DosBox - and out of DosBox..the install is rather quick tho (only like 10 secs..) But doesnt give any errors.
I mount the cdroms like: mount D D:\ -t cdrom
I mount the game dir like: mount C C:\Dynamix\AODCD
The resource.cfg is below
videoDrv = VESA.DRV
soundDrv = ADL.DRV
audioDrv = DACBLAST.DRV
joyDrv = NO
mouseDrv = STDMOUSE.DRV
memoryDrv = ARM.DRV
directory = \DYNAMIX\AODCD
audio = .
SCTDIRECTORY = .
doclanguage = ENGLISH
language = 1
cmd = aod
minCPU = 386
minhunk = 1k
audiosize=64k
cd=yes
[SoundFX]
Driver#=E000
DMA=1
IRQ=7
PortAddress=220
[Music]
Driver#=A002
PortAddress=388
[SoundSet]
pathSoundPlay=.\sound\
pathDrivers=.\sound\
digiFile=.\sound\sonarret.raw
digiName=sonar ping
midiFile=.\sound\departra.hmp
midiName=music
[language]
uselanguage=English
[FlicPlayer]
pathFlic=D:\intro\
Editted by eL_PuSHeR
PLEASE, KEEP SINGLE POSTS IN A SINGLE THREAD. It will be less confusing...
MERGING....
Reply 3 of 8, by LobsterbakXXI
Sorry - I guess I hit the new post button.
Reply 4 of 8, by MiniMax
Rank Moderator
Moderator
LobsterbakXXI wrote:
i installed in DosBox - and out of DosBox..the install is rather quick tho (only like 10 secs..) But doesnt give any errors. […]
videoDrv = VESA.DRV
soundDrv = ADL.DRV
joyDrv = NO
memoryDrv = ARM.DRV
<snip>
The directory entry looks VERY suspecious!! Once you have started DOSBox and mounted the real C:\Dynamix\AODCD as DOSBox's C:\, anything in DOSBox that refers to C:\DYNAMIX\AODCD is really C:\Dynamix\AODCD\DYNAMIX\AODCD - and I doubt that directory exists - or???
That resource.cfg - that is from an non-DOSBox install I assume??
Try to delete everything in the real C:\Dynamix\AODCD, start DOSBox and then mount your C and D drives as you described earlier. Then (in DOSBox) go to D: and run the installer.
_________________
Reply 5 of 8, by LobsterbakXXI
Ok, Ill try that now! Ill let you know if it works. 😎
Reply 6 of 8, by LobsterbakXXI
Ok - the game runs, a little choppy (but i can stand it)
But I have no sound! I ran AOtD Soundset.exe - and it found a Soundblaster 16...but there is no sound in the soundset prog or the game.
Reply 7 of 8, by LobsterbakXXI
Ok - I got it, the nosound line was set to true 😉
Its still a little choppy (the sound..) Ive done everything here on the site..is there anything else?
Reply 8 of 8, by MiniMax
Rank Moderator
Moderator
Check the section on Special Keys in the readme. Look for the keys that will allow you to raise the number of CPU cycles.
http://dosbox.sourceforge.net/wiki/index.php? … age=SpecialKeys
http://dosbox.sourceforge.net/wiki/index.php? … eDemandingGames
_________________
