First post, by aquasync3
Not exactly a big problem, but some games/progs have both an exe and bat with the same name, and tell you to just type the name to run it. In real dos this runs the batch file, but currently in dosbox it is the other way around. Not sure what the priority of .com's are, but that could be easily checked too.
Of course you can just call the .bat explicitly, but it'd be nice to fix this...
Reply 2 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
as far as I know are our priorities correct.
Water flows down the stream
Reply 3 of 14, by dvwjr
The way DOSBOX works is the way that real DOS works. Since DOS 2.x the Command.com execution order has been *.COM, *.EXE, *.BAT.
See this older thread here on the same subject. The *.BAT before *.COM and *.EXE went out with PCDOS 1.x in the early 1980s.
dvwjr
Reply 4 of 14, by avatar_58
Hm....thats odd. Playing many sierra games I am sure .bat loaded first before the others even in the later dos 6. 😖 In fact I'm sure it did...
Reply 5 of 14, by eL_PuSHeR
Agreed. I remember that too, that batch files took preference. But, who is right? I have not documented myself.
Reply 7 of 14, by XulChris
I seem to remember the order being .BAT .EXE .COM. Even if that is not what the original DOS did, it is the order which makes most sense.
Reply 8 of 14, by MiniMax
Rank Moderator
Moderator
"There can only be one..."
An .EXE and an .BAT
The .EXE takes precedence:
Thanks to ImageShack for Free Image Hosting
_________________
Reply 9 of 14, by Guest
Is bochs the exact same as original dos prompt? I'm not argueing my guess but I just remember haveing many games which had batch files in the dir with the same name and they took preference (you could tell because they always had echo off and soemtimes %1 %2 %3)
Oh well, you get corrected every day! 😮
Reply 10 of 14, by avatar_58
sorry...that /\ was me I just hit post without logging in 😅
Reply 11 of 14, by MiniMax
Rank Moderator
Moderator
Define: "original dos" 😀
Bochs is a pure CPU/screen/sound/network/disk emulator. It will (theoritically) run any OS you throw at it. The shoots I took, was with Bochs running DOS from Win95 OSR2.
_________________
Reply 13 of 14, by eL_PuSHeR
On the other hand, it has always seem stupid to me naming a batch file with the same name as its EXE counterpart. 😁
Reply 14 of 14, by aquasync3
Oops, I could swear I double-checked this before posting, but I can't seem to replicate it now... 😒
