First post, by buttertweet
Hi, is there a trick to getting Windows 3.1 to run in 1024x768, 16.7M colors? The OEMSETUP.INF in the 1.70 Trio drivers has it listed, but it can't be selected in Setup. I also tried to use yhkwong's build with vmemsize=4, but still no dice.
Reply 1 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Did you try setup.exe from the dosbox prompt?
Instead of starting windows 3.11, cd to the windows folder and start setup.exe
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 2, by buttertweet
Sorry I fell off the wagon there, but I found the problem. The lines for that resolution are actually commented out in the INF file. I uncommented them, but it still did not work. I went back to the INF and found two sections headed by brackets [D132L] and [D132S], and some of the values under them looked strange. I edited them to roughly match the 16-bit sections, and voila, it worked.
