First post, by noshutdown
noshutdown
Offline
there are many timing numbers in a dram datasheet: trc, trac, tras... which numbers are used in calculating bios dram timing options?
for example, at 66fsb each clock is 15ms, and a typical -60 dram needs 60ms to complete the first page read, so it needs 4 clocks. but which number indicates the time needed for following page reads?
