First post, by superfury
superfury
Offline
When I compile and run UniPCemu for and on Android, it runs, but it's terribly slow(maxes out at 2500 cycles/second(it's CPU emulation is running at 4.77MHz, so it's running at a speed of 2500 out of ~4770000 cycles needed to run at full speed)). On the PC(2.0GHz+ Dual core/Quad Core CPU) this is usually more like millions(2-4Mcycles/second). Anyone knows/can see why UniPCemu is so unusually slow on my Android device(LG-P710)?
The code I'm using is at my repository:
https://bitbucket.org/superfury/unipcemu.git
UniPCemu Git repository
