First post, by almar
fullscreen=true
fulldouble=false
fullfixed=false
fullresolution=1024x768
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
When I open DOSBox using the above config, the screen expands to a huge size The letters are maybe half inch in size and i'm unable to use the command prompt. I've tried different settings than the above but then get a variety of different problems.I've checked previous posts in this forum but this problem doesn't seem to have come up. I'd appreciate any direction you can give me to resolve this little quirk.
Reply 1 of 1, by Guest
I've resolved the problem! I recently updated nvidia driver, bad move, so I've re-installed Ver. 56.64 Now all works ok.
Oh, fulldouble=true
