First post, by hazard94
I'm using Ubuntu 16.04.1 LTS on a netbook. I want to build DOSBox SVN:DAUM. I know I can directly install DOSBox through 'apt-get install dosbox' but I need the daum.
I've downloaded the source of daum and followed carefully step by step the "INSTALL_SVN.txt". Everything went perfect except for the last step, when compiling dosbox itself.
When I execute
./configure --enable-core-inline && make
An error shows up.
[.......] checking for sys/mman.h... yes checking for mprotect... yes checking for setpriority support... yes checking for PHYSF […]
checking for PHYSFS_init in -lphysfs... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
.in'ig.status: error: cannot find input file: `
I didn't copy the whole output to keep it short. If you need it or need more details on something I will post them.
I searched the internet a lot but cannot find anything relevant.
I've followed the instructions perfectly and there were no errors before.
Thank you in advance
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Open config.log to see where the error occured. Latest Daum was broken, btw, I wouldn't recommend that anymore.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 5, by hazard94
Thanks for replying. i checked the config.log and I can see it shows some errors but I can't understand where they actually happened.
However, what do you mean it was broken? Should I stop trying to build it? I couldn't find any source code to older versions.
Here is the config.log file I attached
    config.log
    64.01 KiB
    40 downloads
Reply 3 of 5, by Dominus
DOSBox Moderator
Some things in Daum were btoken (not the building). Depending on what you actualky want it for, building lock stock dosbox svn or dosbox-x might be more useful.
Reply 4 of 5, by Dominus
DOSBox Moderator
Can't figure out what's wrong from the config.log as well. Might be SDL-Sound related.
