First post, by Mut
I'm trying to fix a partially working acumos AVGA2 VGA that one of the transistors was removed.
Someone would have equal VGA could tell me which used transistors ?
    78.42 KiB
Reply 2 of 7, by adalbert
My revision is a bit different unfortunately, but this is what it looks like. There is a chance that D1 and Q1 will be the same part.
    908.78 KiB
    1.11 MiB
Reply 4 of 7, by Jepael
D1 is the "adjustable zener diode" TL431, more specifically, TL431CZ version of it in TO-92 package, by some manufacturer unknown to me (the stylized S letter). Because I don't know the manufacturer, it is quite impossible to know the tolerance of the part, whether it is 2%, 1% or 0.5%.
Q1 is bog-standard 2N3904 NPN transistor in TO-92 package.
Reply 5 of 7, by SquallStrife
90% sure it's Signetics. It's not /quite/ the same as my Signetics parts though, so could be wrong.
Reply 7 of 7, by Jepael
If you are connecting it to VGA port of modern TFT monitor, please make sure (read the manual) that it supports 70Hz formats, because many modern TFTs don't.
