Saved states?
First post, by DosFreak
Ability to save memory location to easily jump to any location in a game for game troubleshooting and playing.
Make your games work offline
Reply 1 of 19, by Snover
Step 1: Freeze emulation
Step 2: Dump DOSBox's internal RAM to file
Step 3: Resume emulation
Yes, it’s my fault.
Reply 2 of 19, by Harekiet
Rank DOSBox Author
DOSBox Author
Hehe if it only were that simple.
Reply 3 of 19, by Snover
Why isn't it?...
Yes, it’s my fault.
Reply 4 of 19, by Schadenfreude
Snover wrote:
Why isn't it?...
CPU register status, status of all HW devices, etc.
Reply 5 of 19, by Daveybaby
Surely all of these states are just variables in the emulator memory space, which can be saved/restored as easily as anything else?
Or did you mean something else?
I know many other emulators which manage this perfectly well. Generally its considered an essential tool for debugging purposes, especially when there's an error that pops up halfway through an emulated game. It also allows your users to aid you by giving you a savestate when reporting a problem.
Crumbs!
Reply 6 of 19, by Finster
Rank DOSBox Author
DOSBox Author
Hehe, it's not that easy. Just some things that came into my mind:
Restoring states:
Some restored variable values may imply actions that need to be taken to restore the state correctly. Simple example: Restoring a file status, you have to do some extra actions like: a) open physical file b) move filepointer etc.. it's not just to save and restore "file xxx hast to be open". There are probably more complex actions in other cases. Not that it is that much of a problem, but it's additional coding.
Object consistency:
Some objects are created dynamically (during runtime) in dosbox. If you restore a state you have to be sure to recreate these objects in the right order and with the right dependencies between them.
Savestate consistency:
Better be sure not to change a lot of variables (and the meaning of their values) that need to be save/restored, cos everytime you do that your old savestate file will be invalidated (file format has changed, there's a missing variable, or whatever, in the old files now). And this will probably happen quite some time as long as you are in development and implement new features. Therefore you need a system that can handle those changes and still read older savestate files (->more coding) or you just dont care and some dosbox users are annoyed cos they cant use their old saved states anymore... 😀
Basically it's some work and it's a error-prone task, dont underestimate it. Take a look at computer games, how much problems do they have saving/restoring their game states correctly ?! Lots of incompatibilities and problems in quite a few (even up-to-date) games.
Besides, it doesnt have high priority atm i guess. 😜
Reply 7 of 19, by Nicht Sehr Gut
Originally posted by Daveybaby I know many other emulators which manage this perfectly well.
But I bet they are console emulators, right? I can see how setting up "snapshots" for a PC emulator could get very messy very quickly.
I remember using an "Action Replay" cart/card on my Amiga and it was fine as long as the game didn't use the OS...or there wasn't more than 3 Megs of memory...or the processor wasn't too fast...etc
Having said all that, the "undo" function in "Virtual PC" works quite well...but the way it works would make for a clunky "quicksave".
Reply 8 of 19, by icemann
Ok well, besides protected games support. What features are currently being worked on at being implemented? if thats not top secret information ofcourse 😜.
Having full support for all of the dos commands is one of the small things I`ve been waiting for, for a while.
Reply 9 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
the internal dos has been updated a bit.
It would depend on which features you want ....
(it's made more compatible)
Water flows down the stream
Reply 10 of 19, by icemann
Well for example all of the dir commands (dir/w, dir/w/p etc), and the edit command (for editing batch files etc).
Reply 11 of 19, by Snover
edit was a program, not a command.
Yes, it’s my fault.
Reply 12 of 19, by oneirotekt
DIR/P, DIR/P/W, and up/down to cycle through the command history have been working for a while now. I really can't think of anymore DOS functionality that DOSBox needs at the moment.
For what it's worth, the version of EDIT.COM that comes with Win2K works perfectly in the current CVS version of DOSBox. So if you absolutely must edit text files from within DOSBox, there ya go.
Reply 13 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
Tab completion is also present.
dir.exe and shortcuts like that are possible as well
dir.vol
del.
Reply 14 of 19, by Daveybaby
Hmmm... yeah, now i've thought about it a bit more - dosbox *is* a more complex job than the average emulator... the main difference being the fact that youre using the same filesystem as the host, instead of running off of an 'image' of a filesystem, like most console and old home computer emulators do.
Its still possible - but it is always a very hard job to plumb something like that in once a project is halfway through... its much easier if the software structure has been designed with that in mind from the beginning.
Crumbs!
Reply 15 of 19, by vladr
DOSBOX is C++; as long as every relevant object has a nicely-writen serialization method... 😀
V.
Reply 16 of 19, by Harekiet
Rank DOSBox Author
DOSBox Author
Hehe it's more like an evil combination of C++ and a C and savestates should also be endian 32/64 bit compatible if you'd want them to be exchangable.
Reply 17 of 19, by Esfiha
Guys, take a look at Game Wizard...
I think thats an better idea to make Game Wizard compatible with DosBox...
PS: Lokk I'm talking about the old versions of Game Wizard, not the new like Game Wiz 1.43 for Win32, cause this don save states, its only for cheathing.
Reply 18 of 19, by Guest
hey guys... first thx fou all tha greAt work! now i can run flashback, syndicate and dune correctly and rock the games like i was a lil poop playing the games of the older brother..
but i dont understand how to quicksave the games... is there an quicksave implemented in dosbox or can i do something (codingless) ?
hmn.. without it , i go mad on flashback! i never can save and when i gotta go afk i cant shut down the game or else i got to do the whole lvl again.. grr.. i cant hold that!
u know smth to save?
just minimizing the window is a lil stressfull
thx!
staychilled
cia!O
Reply 19 of 19, by HunterZ
Nope, DOSBox is very complicated and the authors didn't have quicksave/save state support in mind when they started developing it. As a result, it's going to be a very non-trivial task to implement such a feature.
