First post, by davezave
I got D-Fend because it was rated the best way to use 16 bit programs on a 64 bit machine.
I couldn't install them originally because Windows 7 wouldn't even look at them.
D-Fend looks at them, and tries to install them, but every time it gets to the SETUP.EXE command/file, it returns the error "win setup.exe" is not a valid command. It's not in the filename - in must be within the executable.
How do I get around this?
Thank you.
Dave
