Reply 40 of 44, by BSA Starfire
Here's a picture of the reverse of my Cyrix III 600MHz in case it's of interest.
1.22 MiB
Reply 41 of 44, by gerwin
Carlos S. M. wrote:
I wonder about the VIA C3 Samuel 1 (known as VIA Cyrix III) which is even slower than Samuel 2, but extremenly rare
The Samuel 1 is not that rare, but the cancelled VIA C3 Joshua core is. The Joshua was an actual Cyrix design.
Reply 42 of 44, by j^aws
Is there anyway of forcing these CPUs to be detected as 66MHz FSB at POST? My DFI board can force this through the BIOS, but I have other boards that autodect Ezra-T CPUs at 100MHz, when I'd rather they POST at 66MHz FSB. Thanks in advance.
Reply 43 of 44, by gerwin
May be possible by a CPU pin mod or by changing a connection on the motherboard side. May also be possible by modifying the row of traces on the back of the C3 CPU. I have no clue which trace may or may not affect it.
Here is something similar, where I made a Slot 1 133MHz FSB pentium III default to a lower FSB speed. Either 66 or 100MHz, I cannot remember. Intel SR440BX mods
Reply 44 of 44, by Tetrium
This is what I thought. I did have some difficulty getting one of mine to run. I don't know what board will work with these, the CPU voltages are very similar to the old Mendocino CPUs and those aren't supported by all s370 boards (I think because the CPU voltage was too high for some boards).
My retro rigs (old topic)
Report spammers here!
