First post, by voodoo5_6k
- Member
Hi there,
After a lot of help from other vogons members my current retro project reached the “all hardware is working properly” stage. Better late than never...
So, short introduction to the subject. Earlier this year I thought about adding a real DOS PC to my setup. For DOS games I was happily using DOSBox for years on my gaming rigs. I had even connected my Roland gear (using the Roland UM-ONE Mk. II) to the current machine and felt like I was moving back in time. But somehow, I wanted to have a real DOS machine (last time I actually used MS DOS was when it was the then current OS, then moved on with Windows 9x etc.). And then it started...
I have three options available in storage that would fit the timeframe.
- - Intel Pentium 200MHz on Intel Advanced/ML (256KB L2), 64MB EDO
- Intel Pentium MMX 233MHz on Asus P/I-XP55T2P4 (512KB L2, with TAG-SRAM extension), 64MB EDO
- Intel Pentium Pro 200MHz 1M on Intel VS440FX, 64MB EDO
I played around with all of them, and finally chose the Pentium Pro. One of the reasons for this is that one major theme within my retro systems is the P6 architecture (the other major theme being 3dfx). The other systems will be presented another time. While completing the system, I encountered an issue with the HDD detection. I finally could work around it (with the help of some fellow vogons members) and finalized the build a few days ago. The actual OS (MS DOS 6.22 and potentially Windows 95c as dual-boot) and games are still not installed, I’ll have to deal with this over the next few weeks whenever I find the time for that. But, I already wanted to give everyone interested a first glimpse of the system.
System specifications:
- CPU: Intel Pentium Pro 200MHz 1M
Cooler: Thermaltake Venus 12 (modified to fit & mounted with Socket 8 clamp) + Noctua NF-A8 FLX
Mainboard: Intel VS440FX (BIOS 1.00.18.CS1)
RAM: Kingston 64MB EDO 60ns (2x 32MB)
PSU: Enermax EG301AX-VE(G) 303W
Case: Compucase CI-7106W ATX
Add-in cards:
- PCI1: Diamond Monster 3D 4MB
PCI4: Eontronics S3 Virge/DX 4MB
ISA2: Music Quest PC-MIDI IH9MQ9 (Keropi’s clone card)
ISA4: Creative Labs Sound Blaster AWE64 Gold
Drives:
- FDD: Alps Floppy Drive
SSD: Transcend TS32GPSD330 32GB
ODD: Asus DRW-1814BL
I/O Devices (via KVM):
- Display: Eizo FlexScan F520
Keyboard: Microsoft Natural Keyboard Pro
Mouse: Logitech S96
Speaker: Canton Plus Media 3
MIDI Devices:
- Roland Edirol UM-550 (5 in/5 out MIDI patcher, provides access to the CM-32L and SC-55 for currently three systems)
Roland CM-32L
Roland SC-55
Pictures:
END OF LINE.
