First post, by Razorfish
I installed DOSBOX 0.63. When starting, a first dos-window appears, that dosbox uses my CH flighstick. A second dos-window appears, but remains black with no prompt C: or Z: - Not possible to type anything !!
In the top of the second windows appears CPU cycles 3000, frameskip 0, program dosbox.
I´m using an AMD with 1 GHZ. How can I start Dosbox?
Reply 1 of 5, by eL_PuSHeR
Did you try the obvious, unplugging the joystick?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 5, by Razorfish
Thanks a lot, dosbox works now.
But how can I combine with my CH Flightstick?
Reply 3 of 5, by _aLfa_
I believe there is a patch in sourceforge to make your joystick work 😀
"I only know that I know nothing..."
Reply 4 of 5, by Razorfish
Unfortunately I cannot a find a patch for a CH flightstick in combination with dosbox 0.6x.
Can I use a joystick with the USB-port under Windows ME/DOSBox 0.63 without problems? If yes, which joystick can you prefer?
Reply 5 of 5, by eL_PuSHeR
Hey, Razorback. You mistakenly hit the NEW THREAD button instead of the POST REPLY one. 😁
Editted by eL_PuSHeR. Merging threads.........
Intel i7 5960X
8 GB DDR4 (2100)
