First post, by maverick85
- Member
Hi peeps. I've been able to source a new old stock Chaintech 440BX motherboard (CT-6BTA3) and I'm looking to build around it. Thankfully its able to post and is shiny new. I have also bought a new beige case (Inwin A500) and two slot 1 processors (PII 350MHz and PIII 500MHz). The PII came with a tall heatsink which causes fitting inssues in the inwin A500 as the PSU blocks tall heatsinks so will have to do with the PIII and the retention clips removed as its heatsink is wider but shorter. I have also sourced an ISA soundblaster 16 (CT4170). Any feedback on what I should do with it, what components would go around it for best compatability?
ASRock 98
Win98SE Desktop
ASRock
Intel Core 2 Duo E8400 3.0GHz
1 x 512MB 667 MHz DDR2
Soundblaster SB0100 + Altec Lansing ADA885
ATi Radeon X800XT 256MB GDDR3
1 x SATA 120GB HDD
1 x SATA DVD-RW
