First post, by superfury
I've tested the IBM PC XT RTC with TIMER.COM v1.2, which seems to work without problems. I also want to test the RTC that's on the AT motherboard emulation, but MS-DOS 5.0a doesn't seem to use the on-board RTC? It seems like it just uses the time that's generated by IRQ0 ticks? Is there a way to actually test the IBM PC AT RTC chip?
UniPCemu Git repository
Reply 1 of 4, by vladstamate
The Landmark AT (5170) test bios will test the RTC. It will also test the alarm feature and expect it to fire at the correct time.
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 3 of 4, by superfury
Just managed to fix the CMOS date in the latest commit. Now both MS-DOS and CheckIt! Diagnostics detect it correctly.
The Date Comparison and Real-time clock alarm check out correctly(passed tests). The other two(time-based) tests fail(1.35 apart).
CheckIt! Diagnostics also displays the actual system time of Windows(which is taken at GMT). MS-DOS gives me a time a bit from the start of emulation, while the RTC gives the correct GMT time. Any idea what's going wrong? Why does MS-DOS count from midnight(when the emulator is started)?
Edit: The current source code: https://bitbucket.org/superfury/unipcemu/src/ … MOS.c?at=master
Edit: Btw, the CPU runs at about 75% speed on my AT emulation(using a Intel i7-4790K 4.0GHz CPU). Does this have anything to do with MS-DOS not taking the time set in the RTC(although the date is taken)?
Reply 4 of 4, by superfury
The Landmark AT test BIOS says that the RTC Interrupt(Using the Periodic Interrupt) isn't working correctly ("1 FAILED" is reported). I see the timer (which runs at double the rate, at 64kHz to be able to create a square wave at 32kHz), which is timing out(generating interrupts) at increasing values from: 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x3FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0xFFF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x3FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x7FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x3FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x1FFF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x3FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x7FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x3FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF ... When testing the Real Time Clock Interrupt test of the BIOS.
Also a little question: what happens on an AT CMOS chip with 64 bytes of RAM installed, when bytes 64-127 are read? Does it simply wrap to 0-63? Or do they map to unexisting(always 0x00/0xFF)?
