First post, by MrEWhite
So, I have an IBM PC 365 with a PPro 200 MHz in it, and it works pretty much perfect, minus this issue I've had with two 3DFX Voodoo 1 cards. In Quake II for example, the game's textures artifact, causing multicolor blocky textures after about 10 minutes of gameplay, and the same for Quake 1. And I don't believe this to be a card issue, as this occurs with two Voodoo cards, a Diamond Monster, and a Orchid Righteous Voodoo, both with heatsinks on them. Could anyone help me out?
Edit: Think I posted this in the wrong section, should've been in video.
Reply 1 of 15, by meljor
Check if your driver does not overclock the cards. It should be 50mhz but some cards can be clocked higher or lower by default.
Reply 2 of 15, by MrEWhite
I tried using the latest standard drivers (both), and the driver that came with the card (Orchid).
Reply 3 of 15, by Ampera
Try it in another board, see if it still happens. If it does it is a card problem.
Try different slots on the board.
Try different RAM on the board.
If all else fails, attempt to reflow the card, a makerspace may have a reflow oven you can use for a quick fiver.
Reply 4 of 15, by MrEWhite
Ampera wrote:
Try it in another board, see if it still happens. If it does it is a card problem. […]
Don't have any other boards to try it on at the time
Happens in all slots
Tried three different sticks of RAM
Don't have one near me
Again, these are two different cards.
Reply 5 of 15, by Ampera
MrEWhite wrote:
Don't have any other boards to try it on at the time Happens in all slots Tried three different sticks of RAM Don't have one nea […]
So you're telling me you do not own a single other motherboard with a PCI slot full stop?
Alright.
Reply 6 of 15, by MrEWhite
Alright.
I don't have a slow enough Slot 2 CPU on me, and my P3 is 1.4 GHz, which is too fast.
Reply 7 of 15, by Ampera
It doesn't matter at all. Just use it to test the cards themselves. Even though there are two, not likely they are bad does NOT mean not possible. If they are both good, it's something else.
Reply 8 of 15, by MrEWhite
They post fine and display fine, but the processors I have are literally too fast and games won't launch because of it.
Reply 9 of 15, by PhilsComputerLab
Moved to Video 😀
YouTube, Facebook, Website
Reply 10 of 15, by MrEWhite
PhilsComputerLab wrote:
Moved to Video 😀
Thanks Phil.
Reply 11 of 15, by Ampera
I don't get that. Tomb Raider refuses to run on a later Pentium 3? And posting doesn't matter, if it starts to artifact it could mean there is something wrong with the memory. I am unaware of any Voodoo memory testing utilities, but even they may be faulty if it's a wear issue as it would then only emerge after load.
I mean if your games aren't made well enough to run on a faster system, are you sure it's not the games bugging out?
Reply 12 of 15, by meljor
I had the same problem some time ago when doing benchmarks on all my voodoo's on a tualatin 1,4ghz (Asus Tusl2-c).
The voodoo1 cards (tried 4-5 or so from different brands) and rush cards didn't even display anything when launching a game.
That same system i'm still using with my voodoo5 and it is running fine. The voodoo's worked in much slower systems with no problems at all.
So yes, a fast system can give problems.
Reply 13 of 15, by MrEWhite
What the guy above me says basically, the Voodoos aren't made to run in a fast system. I'll see if I can get it to work on the P2 board I haven't used in a year or so.
Reply 14 of 15, by Ampera
Alright, I never knew that. The knowledge here is general PC Component knowledge, I've never even seen a 3DFX card irl
Reply 15 of 15, by MrEWhite
P2 board wouldn't post, damn...
