First post, by mno
Hi all,
I'm new to DOSBox, and found out about while reading an article and the forums over at Ars Technica (the interview with the creator of Scorched Earth). In any case, I've installed DOSBox 0.63 and D-Fend and tried running OMF2097. It runs, but horribly slow. I could tell immediately because the menu responsivness was horrible. I've tried playing around with the specs, and even turning off the sound, but no luck. It's interesting, actually, but the game ran at the same speed with the sound as it did without it.
My system specs are (taken from dxdiag):
Time of this report: 4/20/2005, 13:15:36
Machine name: LAPTOP
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: Dell Computer Corporation
System Model: Inspiron 4100
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A03
Processor: Intel(R) Pentium(R) III Mobile CPU 1000MHz
Memory: 640MB RAM
Page File: 367MB used, 621MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: None
DxDiag Version: 5.03.2600.2180 32bit Unicode
Full system specs from dxdiag can be found here:
http://max.nokhrin.com/random/DxDiag.txt
