First post, by tabm0de
This is my second old gaming machine I'm working on at the same time.
But this will not be a sleeper so it got new moded black chassi since that's the color now days.
Hardware
Chassi: Chieftec Black with Mesh front panel, 2 x USB 3.0 ( panel removed )
Motherboard: Aopen AX6BC
PSU: some random at the moment but will be changed for a module one sine i dont need all pci-e and sata cables at all...
CPU: p2 300ghz mmx
Mem: 162mb~
Disk: sStarTech.com 3.5-Inch Drive Bay IDE to Single CF SSD Adapter with 16gb card
Floppy: normal one ( have to buy a new one since the black color dont match that good ) and gotek thats on its way
Gfx: unsure now but its better then it should be, i only require quake 1/2 to run ok
Sound: creative sound blaster ct1600
Nic: Realtek
PCI sata controller for bigger disk if i ever needed to mount a disk since bios cant go past 100gb i think it just get stuck at post.
Os: windows 98
Also bought
Brand new intel pentium 2 mmx stickers ( found on http://www.vath.co/ )
Brand new windows 98 stickers ( found on http://www.vath.co/ )
More pictures to come 😀
naa, nothing yet...
Reply 1 of 6, by chinny22
A 300GHz P2!? WOW 😉
Nice build tough. What motherboard you got?
Reply 2 of 6, by tabm0de
Haha forgot to put pII in the header 😉 I use a old hp 486 dx 100mhz for "Old" games :p
But the answer would be Aopen AX6BC 😉
naa, nothing yet...
Reply 3 of 6, by ScoutPilot19
Nice build ! But for my opinion 300mhz is "not enough" for a P-II. I for myself found a Dell P_II with 400 mhz and it runs too slow games easily played on Asus P3Bf with PIII-500 and even with Asus P2Bf/P-II-450 I used to have back then in 1998-2004.
Reply 4 of 6, by Tetrium
Aopen AX6BC is BX and your P2-300 is either Deschutes or Klamath (Klamath being older and hotter).
It's a 66MHz CPU but chances are yours has several unlocked CPU multipliers. It's probably set to 4.5x (55x4.5 == 300MHz) right now. If you feel like some experimenting and don't mind getting barely any real world benefits whatsoever, you could opt to change your board+CPU to run at 3x100 == 300MHz 😁
I do think your case looks too recent, but when looking at what cases are generally for sale these days...your case is a significant improvement 🤣!
My retro rigs (old topic)
Report spammers here!
Reply 5 of 6, by tabm0de
Its an older p3-300 since i want it to work on all 3 motherboards i have. I choosed this case because this one i will use as normal gaming pc for old games upp to maybe right under year 2000 and less and i wanted to skip front usb ports because they arent good for anything really 😉
I also have a sleeper project im working on which has a older beige chassi since thats the way to go 😀
WIP - First Pentium 2 sleeper build
naa, nothing yet...
Reply 6 of 6, by deleted_Rc
That depends were you look. My nanoxia is a very decent tower (with exception it's depth 🤣 ). I admit it's hard to find decent stylish cases (simple but sturdy towers)
