First post, by hydr0x
ok, i encounter that error in various games and after searching a little bit through the board, it seems i'm not the only one...
obviously some change made from 0.61 to 0.62 causes this but i'm not too sure as i didn't use those two versions, just a conclusion made from the facts other people having these problems gave
updating my graphic drivers ain't an option, they are up2date
it has to be SOME setting in the conf file but i tried a lot of stuff, disabling a lot of stuff and playing around, nothing worked. why has it got to be something in the conf? well, i deleted my conf file and booted dosbox without any conf-file and voila, all those games now work!!
so, i'm still trying to find out what exactly causes this (=which setting) but i'm pretty sure it's an easy solution as soon as we find it and i hope this can be fixed in future releases 😀
Reply 1 of 13, by eL_PuSHeR
Try replacing SDL.DLL with a different version.
www.libsdl.org
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 13, by hydr0x
that doesn't help, sorry, forgot to mention it, several other people who have these problems tried it too
here is a list of everything that's different between the standard working dosbox.conf and the one not working
not working uses a language file
working/not working
scaler=normal2x / none
gus=true / false
speaker = true / false
this is the autoexec part in the non working
mount c g:\dosroot
c:
keyb gr
mount d d:\ -t cdrom
mount e e:\ -t cdrom
i'm off to check off all those things
Reply 3 of 13, by hydr0x
omg
it's the speaker setting
speaker must be set to true to avoid this problem 😅
maybe you should make a sticky or guide about this as i've seen several people have this problem and noone found out a solution in those threads...
Reply 4 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
hmm yeah 😀 hmm why disable it in the first place ?
Water flows down the stream
Reply 5 of 13, by hydr0x
i can't remember why i disabled it...
but still, this doesn't seem to happen (with the same setting in pre0.62) and it should not happen, right?
hope other people having this problem will find the solution in this thread
Reply 6 of 13, by HunterZ
Why give the option to disable it if it breaks DOSBox and/or SDL? Qbix, is there a bug somewhere?
Reply 7 of 13, by DosFreak
I've heard alot of games require the speaker....even if it's not used. Never encountered the issue myself since I've never disabled the speaker on a host system or under DosBox.
Make your games work offline
Reply 8 of 13, by HunterZ
You can't "disable" the PC speaker on a real system. You can unplug it, but the hardware that drives it still keeps doing its thing.
Reply 9 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
well The bug is fixed in the cvs.
but it's just uncommon to disable it.
but if you don't like the pcbeeper sounds I can understand it somehow.
Reply 10 of 13, by hydr0x
thx Qbix
well, i really can't remember WHY i did deactivate it, i have nothing against pcspeaker, grew up with it.... it's not that uncommon to disable it, just search for "fatal signal" or something like that here on the board and you'll find quite a lot of people with the same problem 😉
Reply 11 of 13, by arromdee4
I got the same error. Except it was in 0.63 and the cause was completely different.
It appeared to happen (Mandrake Linux 10.1) because I specified 320x200 graphics mode in my .dosboxrc. If I do that and go fullscreen, it crashes. If I change that to 640x400, everything worked.
I do have an appropriate modeline for both 320x200 and 640x400, and when Dosbox crashed it actually left my machine in 320x200 mode, so the problem is not that the mode doesn't work. (Though I suppose SDL might just not handle it properly.)
(By the way, does anyone know how I can recover my password here? I use an expiring email address which I don't remember and which would have expired anyway.)
Reply 12 of 13, by `Moe`
You mean by using fullfixed=true and fullresolution=320x200? Don't do that... it's quite hard to squeeze 640x400 pixels (like the DOS prompt uses) into 320x200 pixels 😀
Why define fullfixed at all? Setting it to 320x200 is as useful as not using it.
Reply 13 of 13, by Guest
I don't have any need to define fullfixed, but that wasn't clear to me at the time.
