First post, by pac00zilla
I am having problems to mount the iso image via .bat dosbox, in windows 7 I created a .bat that mounted the iso of any game and already typed the commands to execute any game via daemon tools, but in windows 10 it is only possible to install the From version 5.0 onwards to the daemon to which the script:
"C: \ Program Files (x86) \ DAEMON Tools Lite \ DTLite.exe" -mount dt, 0,
Does not work, there is a way around this problem.
In case the game was Elder Scrolls II - The Daggerfall (1996)
And this is the complete code I use:
@echo off
c:
if not exist "0.3cd" (
md 0.3cd
cd 0.3cd
if not exist "edagger" (
md edagger
xcopy "X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger" "C:\0.2cd\edagger" /y /s /e
"C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe" -mount dt, 0, "X:\miscelaneo\5_fullgame\0.01msdos\rsdos\edagger\edagger.iso"
del C:\Users\pac\AppData\Local\DOSBox\dosbox-0.74.conf
copy "X:\miscelaneo\5_fullgame\0.01msdos\rsdos\edagger.conf" "C:\Users\pac\AppData\Local\DOSBox"
ren "C:\Users\pac\AppData\Local\DOSBox\edagger.conf" dosbox-0.74.conf
start X:\miscelaneo\2_software_a\emulator.pack_EEC" "2016-08\Emulators\IBM" "PC\DOSBox\DOSBox\DOSBox.exe -s -t 6
:loop
:: esse ping é para 2 segundos (-n 4), para 3s use (-n 5), o valor deve ser considerado com + 2 segundos
ping 127.0.0.1 -n 4 -w 1000
tasklist -fi "IMAGENAME eq DOSBox.exe" | find /i "DOSBox.exe"
if %errorlevel% == 0 goto loop
copy "X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.1normal.conf" "C:\Users\pac\AppData\Local\DOSBox"
ren "C:\Users\pac\AppData\Local\DOSBox\0.1normal.conf" dosbox-0.74.conf
"C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe" -unmount dt, 0
del X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE0 /y
xcopy "C:\0.2cd\edagger\SAVE0" "X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE0" /y /s /e
del X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE1 /y
xcopy "C:\0.2cd\edagger\SAVE1" "X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE1" /y /s /e
del X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE2 /y
xcopy "C:\0.2cd\edagger\SAVE2" "X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE2" /y /s /e
del X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE3 /y
xcopy "C:\0.2cd\edagger\SAVE3" "X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE3" /y /s /e
del X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE4 /y
xcopy "C:\0.2cd\edagger\SAVE4" "X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE4" /y /s /e
del X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE5 /y
xcopy "C:\0.2cd\edagger\SAVE5" "X:\miscelaneo\5_fullgame\0.01msdos\rsdos\0.2cd\edagger\SAVE5" /y /s /e
exit
Reply 1 of 8, by DosFreak
You should not be using Daemon Tools with DOSBox, instead mount the ISO directly in DOSBox.
Also you definetly shouldn't be using Daemon Tools with Windows 10, it causes too many issues in modern versions of Windows.
Finally, why are you using this convoluted batch file? The phrasing of your post and the batch implies this isn't a legal copy.....
Make your games work offline
Reply 2 of 8, by pac00zilla
If I should not use the daemon tools with the dosbox what program should I use to mount the iso on the virtual drive?
How do you copy illegal?
Reply 4 of 8, by Jorpho
You don't need any program other than DOSBox. Just type "imgmount d whatever.iso".
There is an official freeware release of Daggerfall available at https://elderscrolls.bethesda.net/daggerfall/. Many, many people have been able to run this game in DOSBox without much trouble (there are many threads about it here already), and certainly without using Daemon Tools or complicated batch files. If you got the game from somewhere else, then it may have been altered in some unknown fashion.
Reply 5 of 8, by pac00zilla
Jorpho wrote:
You don't need any program other than DOSBox. Just type "imgmount d whatever.iso". […]
I play the cd version that I downloaded in the REMOVED
The bat I wrote does the following:
Checks if the folder in the c: is available if not creates a new folder and copies the files of the game execution to those who do not know Daggerfall needs the cd mounted and the execution files only run in the directory c:
Does the copy the settings that I created with the commands for it to execute the game for the executor folder of the dosbox and there executes the game
If I close the dosbox it will unmount the cd and copy the game saves to x:
With this I do not need to enter any command to execute the game, executing the bat it does everything automatically
Reply 6 of 8, by pac00zilla
collector wrote:
http://www.dosbox.com/DOSBoxManual.html#IMGMOUNT
I did not know IMGMOUNT function, thank you very much, thank you.
Reply 7 of 8, by Jorpho
I don't understand why you are doing that. You can put the files in any folder you want, and mount that folder as drive C in DOSBox.
May I suggest the 60 Seconds Guide?
60 seconds guide to getting your game to run in DOSBox
