C&C Problems on Mac OSX
First post, by ShermDog
I'm having two problems with Command & Conquer on Dosbox running Mac OSX 10.3.9. They don't occur together, rather it's one or the other:
1. When installing the game, I get the following message: "Unable to load SETUP.MIX file from CD-ROM disc."
2. I was successful in installing the game using Petit Dosbox--in fact, I got all the way through the installation process (e.g., settings, soundcard, etc.). However, when I try to start the game, Dosbox crashes.
Does anyone have any idea what's going on here? I'd appreciate your help. Thanks.
Reply 2 of 4, by ShermDog
Excuse my ignorance, but where would I get DOS32a for Mac OSX, or activate it using DOSBox .63?
Reply 3 of 4, by HunterZ
DOS32a is a DOS program, so it doesn't matter what OS you're using if you're trying to use it inside of DOSBox.
Reply 4 of 4, by MiniMax
Rank Moderator
Moderator
There are several threads here at VOGONS that mentions DOS32A. In fact I think there is an announcement thread, started by the programmer behind DOS32a, somewhere - complete with details on where to get it, and how to use it inside DOSBox.
Edit: All about DOS32A here:
http://dosbox.sourceforge.net/wiki/index.php?page=dos32a
_________________
