First post, by vorob
Hello, I’ve got some strange issue that I’m eager to solve here.
I’ve got Windows 10 Tablet from China. It’s called Onda 919 Air CH. It’s based Intel Cherry Trail platform so it has Intel Atom x5-Z8300 CPU and Intel HD Graphics (GEN 😎.
Problem is, that some old games, when launched in fullscreen, starts half rotated, half off the screen:
Only windowed mode helps:
But in this case, in some game, resolution is flexible and calculated based on size of your window, so when maximized it will be near native tablet resolution 2048 x 1536 which is too much and game lags.
The only half-solution i found is to set windows system resolution to 1024x768 and then run game in windowed mode and apply borderless application. In this case game will be fullscreen and in 1024x768. Problem is that some games won't work with this borderless application, Hitman Contracts is an example of such game.
Such rotation issue found it: Warcraft III, Hitman Contracts, Thief Deadly Shadows.
Reply 1 of 9, by vetz
I experienced something similar at my work. Had to setup an android emulator on a computer and the software auto rotated in the wrong direction when in fullscreen mode. Had to force the emulator to display a certain resolution to make it work.
Reply 2 of 9, by Procyon
See if you can test it in Australia, if the games are upsidedown then it depends on the location you are. 😁
On a more serious note, I don't think it's caused by the games but that Windows sees them as phone applications, since I don't have this sort of hardware I don't really know how to solve this.
Maybe you can profile the videosettings for the application indendently.
Reply 3 of 9, by DosFreak
I remember having that issue on laptops that used a Intel video card. Unchecking the rotation checkbox in the graphics card program fixed it but that was before Intel made their program all fancy.
Make your games work offline
Reply 4 of 9, by PhilsComputerLab
Bump
Just wondering if anyone has run into this issue.
Mucking around with a tablet and I've noticed the same issue. It seems that DirectX 8 games are affected. For example 3DMark 2001 or Hitman 2. Whereas 3DMark03 works fine, and so do other games such as TA, Moto Racer and Moto Racer 2.
DOSBox also works fine 😀
YouTube, Facebook, Website
Reply 5 of 9, by ZellSF
Could be a bug because of Windows 8/10's forced maximized window mode, try this:
Fullscreen mode in Direct3D8 games on Windows 10
dgVoodoo2 could also work, but maybe not on the terrible hardware tablets usually have.
Reply 6 of 9, by PhilsComputerLab
I'll check it out, thanks!
Reply 7 of 9, by Lelasin
Have you tried to run in compatibility mode (WinXPsp1)?
Reply 8 of 9, by PhilsComputerLab
Yes I have, and some other compatibility issues. It seems to be a common issue with Tablets. The rotation of the screen and how this is handled seems to be the issue, as notebooks with the same Atom CPU and Intel graphics don't have this issue.
Reply 9 of 9, by PhilsComputerLab
Nailed it! That fixed the issue 😁
Just drop the .DLL into the game folder and all is good. Thank you very much!
