The Yamaha OPL YMF718-S chipset.
Reply 40 of 60, by gerwin
@Anonymous Coward
I opened up the SetupSA.exe in a text/hex editor and noticed the following strings:
"winpath" "winpath95"
system files mentioned:
"\system.ini" "\dosstart.bat" "c:\autoexec.bat" "C:\CONFIG.SYS" "CONFIG.BAK" "Himem.sys"
other files mentioned:
"opl3sa.ini" "opl3sa.bak" "OPL3SA.Drv" "test.ymh" "rec.ymh" "message.tbl" "SETUPSA.EXE" "SACDROM.SYS" "DWCFGMG.SYS"
You can maybe hexedit "winpath" to something else and force SetupSA to use opl3sa.ini instead.
It suggests there are two additional parameters instead of just /S:
/I and /M. Function unknown. Maybe /N too?
Reply 41 of 60, by Anonymous Coward
I think the behaviour of the software must indeed vary according to which operating system is installed. When I have a moment I will attempt to hexedit setupsa as you have suggested.
Very interesting that you pointed out there are additional parameters available for setupsa. However, do to the poor documentation online, I doubt we will ever be able to determine what they actually do.
Reply 42 of 60, by Nahkri
I have a soundcard with the ymf 719 chip and under windows u can activate a softsynth wavetable.
Can u activate it under dos too?
Reply 43 of 60, by gerwin
Never bothered with the softsynth. Quite sure there is no DOS version of that software, DOS is not a good OS for making softsynths (as TSR's).
You might want to consider an Internal or External hardware synth.
Reply 44 of 60, by bristlehog
Nope, the OPL3SAx (YMF719) softsynth is Windows only.
Hardware comparisons and game system requirements: https://technical.city
Reply 45 of 60, by copados33
Does anyone know where I can get the W98 driver for this card? its an Addonics equipped with a Yamaha YMF 701-S OPL chip.
Reply 48 of 60, by copados33
Thank you guys @gdjacobs
Reply 49 of 60, by r00tb33r
samudra wrote:
Consequently I find out this card is made by Addonics Taiwan and find the generic drivers for this chipset on the Yamaha website […]
Consequently I find out this card is made by Addonics Taiwan and find the generic drivers for this chipset on the Yamaha website.
http://www.yamaha.co.jp/english/product/lsi/d … load/index.html
Image of the config utility:
The website has changed and the chipset is no longer listed there, and no downloads.
I'd really like this utility. Do you know the file name or could you upload the driver package?
Reply 50 of 60, by gdjacobs
Follow my link above. Yamaha just moved the files.
Reply 51 of 60, by r00tb33r
Thanks!
Got sound out of it, but sound effects in Doom are breaking up. Like some weird gargling effect. Synth sound is very pleasant however.
Is there something else I need to disable to fix the sound effects?
[EDIT]
Maybe it's reverb... It sounds awful.
Reply 52 of 60, by dries_86
Hi
I recently bought this card Yamaha OPL3SA2 YMF718-S.
I want to use it in a MS6309 Motherboard with 1x 16-bit ISA slot (slot is a little bit longer than the card but I guess this is normal?).
I reinstalled Windows 98SE and the card was automatically installed with WDM drivers, however no sound (headphones plugged in to speaker output).
Then I downloaded and installed the Yamaha drivers from Phils Computerlab, went very fast without problems. The device was then recognized as "YAMAHA OPL3-SAx Sound System" and I got some control panel but still no sound in DOS or Windows. I also ran the SETUPSA.exe in DOS (added to autoexec.bat) and it said correctly configured. No errors whatsoever.
What am I doing wrong because I'm thinking the Speaker output of the card may be broken (however it was sold as working) ?
Reply 53 of 60, by dries_86
I checked with the vendor and he told me it's not possible to use headphones with this card. Only active speakers work in combination with this card.
Did not know sound cards like this exists..
Reply 54 of 60, by gdjacobs
I have a SB16 without the amp chip. So, same idea.
Reply 55 of 60, by dries_86
Ok so it's correct what the vendor is telling me and for my purpose (using it with headphones) I should find another card ?
Reply 56 of 60, by gdjacobs
Or run it through an amp.
Reply 57 of 60, by dries_86
I tested it on my Yamaha YHT1810 Home Cinema (suppose this qualifies as an amp) by a cinch/RCA cable and to the 3.5 mm SPKRS output on the card .
Looks like my card is correctly detected in Windows & DOS (can run SETUPSA.EXE and amend settings).
However still no audio output in Windows98SE (checked all volume settings-also advanced) or DOS.. Suppose this card is broken or am I doing something wrong?
Reply 58 of 60, by greasemonkey90s
Anyone have experience with the onboard variant ymf-701? My hp socket 7 pavillion has this chip with what looks like a ess daughter board with the actual speaker inputs.
Reply 59 of 60, by gdjacobs
If the setup works with another 1/8" audio source, yes you'd have to do some further troubleshooting. Know anybody with an oscilloscope?
