Reply 20 of 32, by konc
Deksor wrote:
Did you try to update (or downgrade ?) the BIOS and look if that can fix this problem ?
Yes, it's on the list of the things I tried in the first post. I upgraded to the latest BIOS available for this board.
Reply 21 of 32, by meljor
which board is it precisely?
Reply 22 of 32, by konc
It's the Intel "Orlando" NV430VX
http://www.elhvb.com/mobokive/Archive/POWER_U … el/28182101.pdf
If I'm not mistaken, it was only made for OEMs with minor defferences, for example mine doesn't have the on-board sound card.
Reply 25 of 32, by appiah4
Have you tried changing the PCI port of the Voodoo Card or even switching the 2D passthrough and Voodoo card around? Sometimes PCI cards work in some slots and not others - the topmost slot was what I used for Voodoo cards in some builds IIRC because the others could prove problematic. It could be an IRQ conflict of some type; I would try going into BIOS and disabling Automatic PCI IRQ assignations and manually assign IRQs only to ports I actually use and see if that helps..
Also, have you tried to see if it works with one of the EARLIER BIOS versions? It could be a PCIset issue that presented itself in a later BIOS and went undetected as Voodoo cards were not a thing back then..
Reply 26 of 32, by Jo22
PCI uses "INTs", not IRQs.
https://www.safaribooksonline.com/library/vie … 1s03s01s01.html
Just nitpicking.. 😉
Reply 27 of 32, by appiah4
Just nitpicking.. 😉
Sorry, I stand corrected, it might be conflicting INTs 🙁
Reply 28 of 32, by Jo22
Nah, that's okay; IRQ is commonly used as an abbreviation for "interrupt" (-request).
Really just wanted to mention that link. It tells about the (physical) differences about ISA/PCI.
On PCI, not all slots are handled equally. On the computer side, INTs are mapped to IRQs.
And since the compatibility issue seems to be more hardware (bus) related, I wanted to point that out. 😀
Reply 29 of 32, by meljor
These cards do not use an irq adress.
I don't know a solution to this problem, it's just strange that windows works fine. Maybe another bios version but otherwise i don't know what i would try.
Perhaps other memory, psu or harddisk as these things can cause strange behaviour.
Reply 30 of 32, by konc
Now that's something I haven't tried. I'm not sure though how I can, there doesn't seem to exist an earlier BIOS available online.
About changing slots and components, unfortunately those are all done and listed in the first post. Maybe another direction would be to start thinking what Windows might be overriding/changing that makes the card work.
Reply 31 of 32, by appiah4
The first thing that comes to mind is that Windows is a PnP OS and your PCI configuration may be set to PnP (Auto) and DOS can't handle that well; have you tried setting your ISA/PCI slot configurations manually in BIOS?
Reply 32 of 32, by konc
Sadly yes, that one was really probable and I was certain that playing with these would fix it.
konc wrote:
-Played with BIOS settings by trying the IRQs in auto, manual, reset settings to default.
