Run MODE.COM on XP
First post, by Unregistered
when i tried to launch MODE.COM in autoexec.nt like:
%SystemRoot%\system32\mode.com
I simply got "Bad Command or File Name"
When I try display it at the same line of autoexec.nt
dir %SystemRoot%\system32\mode.com
It appears ok ("MODE COM 19968 02.07.26 4:00p")
And, others Command(dosx, redir ...) Runs OK.
Why only for mode.com??
Reply 1 of 11, by Nicht Sehr Gut
Moved thread as it doesn't appear to have anything to do with VDMSound. Actually, I'm not sure what's trying to be done here.
I ask that the poster come back come back and clarify a few things: What are you attempting to do and why?
Reply 2 of 11, by Stiletto
It appears he wants to use MODE in Autoexec.nt but it's telling him it can't find the file.
http://www3.sympatico.ca/rhwatson/dos7/z-mode.html
That is a weird bug, though. I haven't seen it before. I'll try it out later.
do the Fandango!" - Queen
Stiletto
Reply 3 of 11, by Stiletto
I tested both at command prompt within Windows XP. Both worked. Uh, you try, Mr. Unregistered.
Stiletto
Reply 4 of 11, by Snover
Mr. Unregistered can't post in here. Mwahahaha. 😉
Yes, it’s my fault.
Reply 5 of 11, by Nicht Sehr Gut
Yes, but why? What's the purpose? Does it have something to do with VDMSound?
Reply 6 of 11, by Nicht Sehr Gut
I missed something. This wasn't "Raider", was it?
Reply 7 of 11, by Stiletto
I'm confused. Why'd you move the post? What's going on?
Stiletto
Reply 8 of 11, by Nicht Sehr Gut
Stiletto wrote:
I'm confused.
Join the club.
Can't find the original location, I think it was VDMSound. In any case, it appeared to have nothing to do with the post.
What's going on?
Good question. I thought Millyways was accessible for Unregistered posters.
Reply 9 of 11, by Snover
The only forums that are available for anonymous posters are VDMSound > General, GliDOS > General, and OpenGLide > General.
Yes, it’s my fault.
Reply 10 of 11, by Nicht Sehr Gut
Ok, then it was my goof. I'll move it back, but I'd like clarification on what's trying to be done by the original poster.
Reply 11 of 11, by Snover
Not seeing any... 😉
Yes, it’s my fault.
