First post, by olspookishmagus
- Newbie
Hello.
With MS-DOS's more not being an option, I was wondering...
is there a pager for DOSBox?
Thanks in advance.
Hello.
Thanks in advance.
May I ask why it isn't an option for you? Not being smart or anything, only because unless it's a special case it can be used.
wrote:May I ask why it isn't an option for you? Not being smart or anything, only because unless it's a special case it can be used.
Because, it would render my DOSBox installation non-clean.
Also I would make a request for it, because others might also want to keep it clean.
What do you mean pager and non-clean? I've no idea what you're talking about.
wrote:What do you mean pager and non-clean? I've no idea what you're talking about.
By "pager" I'm talking about this:
cat looooooong.txt | pager
It will will output that looooooong text in one screenful after the other.
By "Non-clean" I'm having in mind the differences between the software licenses of DOSBox and MS-DOS.
If I'm up-to-date and correct Microsoft has released source for MS-DOS versions 1.0 and 2.0 only.
4Dos? FreeDos?
wrote:4Dos?
FreeDos?
Or MS-DOS, that's not the issue here.
I should have been more clear in my initial post.
I'm looking whether a pager already exists within DOSBox.
No, it doesn't but you can use free utilities that you can place in your path and use in Dosbox
wrote:No, it doesn't but you can use free utilities that you can place in your path and use in Dosbox
Ok. I got my answer.
wrote:wrote:No, it doesn't but you can use free utilities that you can place in your path and use in Dosbox
I'm kind of puzzled since you mentioned initially that you want it "clean" and then
wrote:Or MS-DOS, that's not the issue here.
So I'm just going to let it here as extra info either for you or anyone else: you can use MS-DOS "more" as long as you set the version right and don't use piping but redirection.
For example instead of textfile.txt |more, use more <textfile.txt
wrote:For example instead of textfile.txt |more, use more <textfile.txt
I suppose it might not work with the oldest versions of "more", but "more textfile.txt" works perfectly without any piping or redirection.
I will add that the version of "more" in FreeDOS is probably licensed at least as permissively as DOSBox itself.
Here you go.
http://reimagery.com/fsfd/txtutil1.htm#less
wrote:I'm kind of puzzled since you mentioned initially that you want it "clean" and then
wrote:wrote:4Dos?
FreeDos?Or MS-DOS, that's not the issue here.
True. I kind of contradicted myself there, please excuse me
What I had in mind is that if one had to use an external pager it would also ideally have to be something clean if possible.
wrote:Here you go.
/me bows
There are many good unix-like utils in the DJGPP package.
http://www.delorie.com/djgpp/
many of them work flawlessly under DOSBox, some others not so much (e.g. the GCC compiler is buggy due to no LFN support in DOSBox).
