First post, by Smack2k
Here is my build...its a 2003 build
ANTEC 350W Power Supply
ASUS A7N8X-X Motherboard
2.5 GB RAM - DDR
AMD Athlon XP 3200+ (2.2 GHZ)
ATI Radeon 9800 Pro
Soundblaster Audigy 2 with Audigy 2 Drive
Machine starts to power on, last about 4-5 seconds and powers off. The board power is still on, but all fans (Power supply / Processor / ATI Card) stop and there is no more activity on anything. I have re-seated the cards / RAM / wires / cables in the board as well as tried each RAM stick individually in the main slot with the same outcome each time. I have removed power from various things (both CS-ROMS for example) and tested.
Anything else I can try or look at? The processor is OK for this board according to everything I have read online, so not 100% sure what is going on.
Reply 1 of 14, by CkRtech
Independent of possible configuration issues, Antec power supplies (at least from the early-mid 2000s) are a major red flag due to their use of Fuhjyyu capacitors. Sadly, everyone recommended them at the time and thought they were amazing. In truth, they aren't - unless they have been recapped. I believe they are otherwise designed well.
I would try another PSU.
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 2 of 14, by Koltoroc
I suspect the PSU is either broken or insufficient. Remember, The athlon XP draw most power from the 5V rail and models like the 3200= can draw 70-80W Power. Make sure you have enough amps on the 5V rail, 30 Amps or so should be ok IIRC, but that still might be a bit on the low side. Has been ages since I had to deal with Athlon XPs, but PSUs with weak or low quality 5V rails have always been a major issue with those.
Reply 3 of 14, by Fusion
I hope you can get the PSU replaced, that is a kick ass system. I loved my 9800 Pro. I wish I kept a lot of the cards I had from that era.
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 200/186 - SB Live! 5.1 - Windows ME
Reply 4 of 14, by deleted_Rc
I have nearly the same build and you need at least 35A on the 5V rail and 350W is barely enough power I advice 400+
Reply 5 of 14, by Smack2k
Looks like I will be buying a new PSU
Any advice on a decent but not overly expensive PSU with molex power plugs including at least one floppy power cable. Although I could just get the adapters for those.
EDIT - I just did a PC Power Calculator breakdown on the Cooler Master site and it came out recommending a 350W Power Supply and a 303 W Load Voltage.....
Reply 6 of 14, by Koltoroc
The calculator is pointless in this instance. It is not a case where the total power is the problem, the problem is, that this particular build needs a very high amount of power on the 5V rail and only a comparatively small amount on the 12V rail since the CPU is fed from the 5V rail. A common problem with all socket a builds. And that is where it gets difficult. Modern PSUs are designed around having most power drawn from the 12V rail and that means that most manufacturers don't put a huge emphasis on the power of the 5V rail, which means most modern PSUs have around 20-25A on the 5v rail, which is not enough for this build. You need 30-40A for this build and I can't even think of a decent modern PSU below 700W that supplies that. And hose PSUs might even cause trouble because of the unusual load you would put on them.
The best bet would probably to get a used PSU from the same time frame as the rest of the hardware and from a good manufacturer and recap/rebuild it.
Reply 8 of 14, by Smack2k
Thanks for the examples....I am going to pick one of them up, check it out when it arrives and hope it works good...I can deal with fixing it when needed...
Any good write-ups / how-tos on re-capping / fixing PSU's? I can solder OK, but never did a Power Supply before.
Reply 9 of 14, by gdjacobs
Replacing the caps is straightforward. The key is identifying the old caps and choosing appropriate replacements. Helpful in this regard is having a good resource for datasheets such as this archive posted via badcaps.net. You can then order new replacements of appropriate spec from a reputable vendor (ideally not eBay).
http://www.paullinebarger.net/DS/
Temperature should be as good or better than the original. ESR or ripple current should be similar to original as should capacitance. You will also need to choose replacements which fit into the footprint of the original caps.
Reply 10 of 14, by Smack2k
Excellent...I enjoy learning new things and really enjoy seeing them through to completion, so this will be an exciting new venture for me...I will practive on some of the PSU's I have currently before I would touch one that is important.
EDIT - Back to the power supply, My Antel SL350 has 35A on the +5V rail according to this - https://www.newegg.com/Product/Product.aspx?I … N82E16817103913 - doesnt that match the others in that list of PSU's? Just trying to get a better understanding of what I am looking at.
Reply 11 of 14, by gdjacobs
Yes, but also check the combined power handling of the 3.3V and 5V rails. Furthermore, if your caps have degraded, the rails might not be holding in specification or even settling during power on.
Reply 12 of 14, by deleted_Rc
on top of that, take in account a good brand of caps like panasonic. Most caps aren't really expensive mostly below $1,-.
Documentation will likely be lacking for such old PSU, so I suggest taking it apart and just identify the bad caps and replace those. I choose a more rigorous approach and just replaced all of them just incase this netted me around $30,- where as the the 2 buffers were most expensive to replace and I also replaced the fan.
Reply 13 of 14, by gdjacobs
Purchasing from a reputable supplier like Digikey or Element14, probably the only brand to actively avoid is Vishay.
Reply 14 of 14, by Smack2k
Update - The issue was in fact the PSU...I got a new 420W PSU with higher Amperage on the +5 rail and the machine booted up fine and I was able to get it installed this past weekend...
Thanks for the help!
